its a r34 gtt with a r33 gtr head and 3L bottomend.
i left a message on your ans machine and sent a msg to your mobile about my specs trent but here is is again.
rb26/30
gt35r .82
18psi
standard oem cams
standard valve springs
intake port matched and polished to runners
3.5" dump
3.5" straight pipe exhaust
5" cannon
cp pistons
spool rods
9:1 comp
cosmetic head gasket
china brand fmic with 3" intake side pipe 2.5 exhaust side pipe (my guess as to the problem but no proof or expertise to back it up)
Nismo Twinplate Coppermix clutch
splitfire coils
340rwkw
to be honest trent ive called a few shops and like the forums everyone seems to have different opinions as to why it wont make more then 340rwkw regardless of how much boost i dial in.
psi drop on cooler
head flow
valve springs
cams
rather then spending money on things i dont need i would like to get the car tested and what ever it needs, i can replace.
Edited by Jap_Muscle
1st post - you wanna just start porting/polishing
By the 4th post you want to actually check whats going wrong... AMEN.
After 12 months of us all (in FI section) telling you to get the current setup checked by a knowlegeable professional, it seems you are finally coming around!
Stop with the "I want to change stuff" and start with the "I need to FIX my current setup first".
We've been telling you for ages to get the cooler pressure drop & valve springs checked... :D
No offence with the above, I'm just totally at a loss as to why you've still not done anything that anyone has recommended for over a year
Trent - before looking much more into it, go over this guys past thread history and have a read of what people have tried to help with so far.
15mins reading will save you hours of rechecking :)
ash i just wanted to talk to someone about my porting and polishing options and wether or not i do really need it. i dont think you can fault me for trying to find out what i should do from a expert. but your right i have taken my time in seeking help but its not easy for us uni students. money isnt that free. although i do want to say sometimes to fix things i do need to change things.
moving forward though as i said id just like to talk to a professional on what the next step should be. Because really if i dont need springs why should i buy them. so i have officialy taken your advice and am seeking out experts to get my setup checked.
ive contacted Rob @ sab automotive, and i wouldnt mind getting trents throughts on things to.
cheers
hmm i will listen to message when i get to work in the morn and check all the threads for things that have been covered. (was offsite all day today, out west actually)
being a 26 head it should be fairly straight forward. Just quickly whats the exhaust cam wheel set too?
im not sure that was ever changed trent as its still running the standard oem rb26 cams.
Put a better quality intercooler in. Drop in some poncams. 360+ kw :D
the problem is that people people have made close to 400kw on standard cams. so really if its possible i dont want to waste my money on cams and lose out on bottom end torque, which is really where i want it all to be.
most likely ill need a 100mm intercooler.
With a 3ltr it will take a bit of cam compared to a 2.6, either way it is NOT the cause of your problems currently.
Depends on what work gets done to the head etc as to what specifically you put in there.
Yes you can play the uni card dude, but you don't build a 400rwkw setup working 4hrs flipping burgers @ maccers :P
You don't need to change anything ATM to fix whatever issues you have, simply because you don't yet know what is wrong.
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
