Wtb S2 Rb25det Coil Pack Boots Or Dead Coil Packs With Good Rubber Boots
im after a few s2 rb25det coil pack boots or if s1 rb25det are the same or rb20det if they are the same?
need asap, want to book in nistune but need the fix the coil packs first!
only after the rubber boots they have to be in good condition
thanks
I'VE GOT SOME IF YOUR INTERESTED THEY BEEN SITTING AROUND FOR 2 YEARS IN MY GARAGE $100.00 IF YOU WANT CALL ME 0431 048 154 POSTAGE EXTRA I GUESS OR I CAN MEET U IF UR IN MELBOURNE IM IN NORTHERN SUBURBS
hey amte thanks but i don't wanna pay that much, they can be dead coil packs im just after the boots
i will keep it in mind anyway
cheers
cheers
when do you need them by?
Shoot me 10 bucks for postage and ill send 6 down to ya, off an rb 20 but they shouldnt be any different...
Cant believe someone closer doesnt have an old set laying around.
hey mate cheers send ur bank details and i'll put the $$ in
hmmmm ill be very very surprised if that fixes the issue..
the issue was that one of the coil pack boots was ripped almost in half where is sits over the spark plug, and a few of the old ones where dry and cracking. so by getting more boots fixed the issue
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
