I have for sale a 1994 Nissan Skyline R33 GTS-4 turbo for sale. The GTS-4's R33's (R32's were turbo) only came out non-turbo. So this car is rare and has been converted to turbo by using the 4WD Stagea (wagon) engine and turbo with 46000km's on it, this car is very rare. I wanted a R33 4WD turbo so i had to get it converted into turbo. The only other option is the R33 GTR but of course cost too much.
The car has the following parts done to it:
* HKS 4" super dragger exhaust
* RB25DET Stagea with now around 50000km's on it
* Turbo timer
* Momo steering wheel
* TV (but still in japanese)
* Front mount intercooler
* Boost gauge
* 3 point immobilizer
* GTR wing
* HKS air filter
* Daikan heavy duty clutch
* the usual CD and MD stackers
Plus maybe a few things i forgot. The license plates on the car are XEN-833. Also just to note, the car is very clean inside.
The car has always been kept at 7psi and very rarely been "flogged". The reason why i am selling is due to running costs but to mainly just pay off my personal loan.
Please email me for any questions or SMS me on 0421830772. If you are interested, your welcome to contact me as i want this sold asap. Im not sure how to do it exactly but i do have pics of the car.
Regards,
Luke
EDIT: Price is $17500
six it sounds to me likw u are after this perfect skyline. man u will never find one as such anyone of them will have something wrong with it. man
Six,
the odometer in the car reads at 95000km's but with the Stagea (4WD Nissan wagon) that was put it, ihas about 50000km's, only put about 6000km's since it was converted.
the colour is white, and about power output, i wouldnt really know, ive never dyno'ed it, but i can tell you it grabs off the mark due to the 4WD.
the brakes havent been upgraded, but the ones on there now are fine, the guy that did it for me said they are fine aswell, it stops me quickly with the ABS, if your racing with this car, well that might be another matter.
after the frount mount intercooler was put on and 4" supper dragger, which was a few months ago, it was tuned, but not dyno tuned, and is working perfectly fine.
oh also to note that we have put on a new condenser to get gas for the air-conditioning, the other one was damaged when the motor was put in. also to get the blue slip passed where about to put the stock air filter back on as mechanics cant pass aftermarket air filters, after its passed we are putting the after market HKS one back on.
any more questions? feel free to ask away.
regards,
luke
NOW $19500!
it has to be sold asap. if someone were to buy it off me at this price im going to re-gas the air-conditioning, get the blue slip done, pink slip and re-register it all for you with 12 months rego!, all worth around $900. the aftermarket HKS air filter will be put on after the blue slip has been passed.
i want this gone asap as im getting desperate for money as ive just bought a get around car and to pay of bills/loan.
regards,
Luke
  • 3 months later...
where abts in syd?
would be interested if u could provide me with a dyno sheet proving car's power
Im located in western sydney, in Marayong with surrounding suburbs like Blacktown, Kings Langely etc near by. I have never dyno'ed the car so i wouldnt have a clue on whats its output is. Id say it would be virtually the same as a GTS-T. Its running a standard 7psi but this has the advantage of the 4WD. It takes off really well while dropping the clutch with all 4 tyres biting and grabbing while it launches.
Just email me if you like to come over to see it or just give me a buzz, more than happy to tell you more about it.
    • OK, Step 3, if you need to remove the valve body, either to replace it, the TCM, or to do a more complete drain.  First, you need to disconnect the TCM input wires, they are about half way up the transmission on the drivers side. One plug and the wires are out of the way, but there is also a spring clip that stops the socket from sliding back into the transmission. On my car the spring clip was easy to get, but the socket was really stuck in the o-ring of the transmission housing and took some.....persuasion. You can see both the plug to remove (first) and the spring clip (second) in this pic Incidentally, right next to the plug, you can see where the casting has allowance for a dispstick/filler which Nissan decided not to provide. there is a cap held on with a 6mm head bolt that you can remove to overfill it (AMS recommend a 1.5l overfill). Final step before the big mess, remove the speed sensor that is clipped to the valve body at the rear of the box.  Then removal of the Valve Body. For this the USDM Q50 workshop manual has a critical diagram: There are a billion bolts visible. Almost all of them do not need to be removed, just the 14 shown on the diagram. Even so, I both removed one extra, and didn't check which length bolt came from which location (more on that later....). Again it is worth undoing the 4 corners first, but leaving them a couple of turns in to hold the unit up....gravity is not your friend here and trans oil will be going everywhere. Once the corners are loose but still in remove all the other 10 bolts, then hold the valve body up with 1 hand while removing the final 4. Then, everything just comes free easily, or like in my case you start swearing because that plug is stuck in the casing. Done, the valve body and TCM are out
    • OK, so if you are either going for the bigger fluid change or are changing the valve body which includes the Transmission Control Module (TCM), first you should have both a new gasket 31397-1XJ0A and a torque wrench that can work down to 8Nm (very low, probably a 1/4 drive one). You can probably get by without either, but I really didn't want to pull it all apart together due to a leak. First, you now need that big oil pan. The transmission pan is 450 long x 350 wide, and it will probably leak on all sides, so get ready for a mess. There are 24x 6mm headed bolts holding the pan on. I undid the 2 rear corners, then screwed those bolts back in a couple of turns to let the pan go low at that end, then removed all the middle bolts on each side. Then, undo the front corner bolts slowly while holding the pan up, and 80% of the fluid will head out the rear. From there, remove the remaining bolts and the pan is off. You can see it is still dripping oil absolutely everywhere...it dripped all night.... I got another couple of litres when I removed the pan, and then another few when I removed the valve body - all up another 4l on top of the 3 already dropped in step 1.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
