Hey Hey,
I have heaps of Skyline gear i have collected of the years! i have R32 and R33 S1 and S2 Stuff and if i havent advertised it, just ask and ill see if i have it or if i can get it for you. Cheers Ty
#1 R33 Series 1 spoiler (black) $50 ono
http://www.nissansilvia.com/forums/index.p...ttach_id=280322
#2 Unknown Brand Cannon $30
http://www.nissansilvia.com/forums/index.p...ttach_id=280342
#3 Apexi BOV (ok condition, gr8 sound) $50 each (got two)
http://www.nissansilvia.com/forums/index.p...ttach_id=280323
#4 Series 2 two door tail lights and rear garnish $100
http://www.nissansilvia.com/forums/index.p...ttach_id=280346
#5 Series 2 dash (ok conditon) $100 ono
#6 Rear Hicas unit $50
#7 R33 fuel tank (gd condition) $50 ono
#8 Passengers Side Mirror $50
#9 Drivers side door with glass $80 (gd condition)
http://www.nissansilvia.com/forums/index.p...ttach_id=280344
#10 Drivers and Passengers door trims (gd condition) $40 each
#11 Indicator/Wiper Assembly $30
http://www.nissansilvia.com/forums/index.p...ttach_id=280347
#12 Front hubs (LH and RH avaliable, 5 stud) $60 each
#13 Front Assemblies (knuckles and upper arms) $60 each
#14 Rear seat (ok condition) $30 ono
#15 Complete S2 RB25DET engine loom (includes injector loom) $150
http://www.nissansilvia.com/forums/index.p...ttach_id=280350
#16 Complete Dash loom $30
http://www.nissansilvia.com/forums/index.p...ttach_id=280352
#17 Petrol Flapper/door $10
#18 Rear 2 door interior quarter panels $40 each
#19 Windscreen Washer Bottle $20
http://www.nissansilvia.com/forums/index.p...ttach_id=280336
#20 Set of 17"x7" rims (good tires on 2, other 2 need replacing), $600 ono
minor gutter rash but overall pretty good, (will not fit over large brake calipers)
#21 Digital Climate control Unit (r33) $40
http://www.nissansilvia.com/forums/index.p...ttach_id=280351
#22 Accelerator Pedal and Cable $40
http://www.nissansilvia.com/forums/index.p...ttach_id=280354
#23 Set of 5 seatbelt for an R33 S2 $50 (gd condition)
#24 Steering Column with Barrel, Key and Trim surrounds $80
http://www.nissansilvia.com/forums/index.p...ttach_id=280357
#25 Hks SSQ (gd condition) with rb25 adaptor $70
#26 Front RH and LH Guards (White in colour and gd condition) $120 each
#27 Reo Bar for behind R33 S2 Dash (Straightand good condition) $40
#28 R33 Engine Crossmember $50
#29 R33 Stock Airbox and Snorkel (gd condition and gd filter) $80
#30 Flywheel and Bolts $80
#31 Extreme Heavy Duty Clutch and Pressure Plate (gd condition, hardly used) $100
#32 R33 Brake Booster and Cylinder (no plundger) $50
#33 Glove Box from a R33 S2 $40
#34 R32/33 Stainless Steel Intercooler piping $100
#35 Manual R33 Brake Pedal $30
#36 Heater core/Unit from an R33 $40
#37 SRS Passengers Airbag, S2 Steering Wheel with Airbag and Airbag Module $make an offer$ (not activated)
#38 S2 Pink Label AFM $110
#39 Stock Rear Bar for an R33 (need respray) $40
OPEN TO OFFERS. NEED THIS STUFF GONE OR ITS GOING TO THE TIP.
Just ask if u need anything else OR Pictures, send me a PM, ill see what i can do.
Cheers Ty
https://www.sau.com.au/forums/topic/336267-r33-part-out/
Hi I can't send a pm as I don't currently have enough posts.
I am interested in:
and probably some other stuff for a 2 door s1 turbo
Pm me your number and ill give you call to arrange a time to come get the stuff
Edited by k speed
https://www.sau.com.au/forums/topic/336267-r33-part-out/#findComment-5459961
hi, ill take the piping if no one has!!... how many pipe pieces?, 3 or 5??. thanx any pix.. i got got on this if its ok.. thanx
Edited by seriesII
https://www.sau.com.au/forums/topic/336267-r33-part-out/#findComment-5471593
Hey mate,
All yours!
To see pictures type in ' stainless intercooler piping ' in the topic search
and look about 4 or 5 down for a post from 'sus32' it's got a picture there!
Cheers Ty
https://www.sau.com.au/forums/topic/336267-r33-part-out/#findComment-5472185
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
    • Staring on a stand is no issue. You just have to wire everything up, give it fuel and cross your fingers that the stand is robust enough. Arranging the inlet plumbing is often the hardest part, without any surrounding structure to hand some of it from. No need for coolant if you only want to run it for <1 minute. As to the gearbox - I think the little Aisin box is a bit stronger than the other small Nissan boxes that went behind SRs, but I wouldn't be too keen to test its limits with the torque of a boosted 25. I don't know if you can retain the box and the tailshaft. The box won't connect to the RB without an adapter of some sort, which is either a plate that will push the engine forward (which is not good for fitting it into the bay's available space) or push the box back, which messes with the box position and tailshaft length - OR - cut and shut work on the bellhousing, which is a long way from "least modification". I'd be buying a new 370Z 6 speed or similar, doing what has to be done to that to make it fit RB (ie, cut and shut bellhousing) and the requisite tailshaft custom/mods.
    • Hi Everyone I am from West Pennant Hills in NSW. Been too busy until recently to attend to my RB25DET Series 2 engine until recently. I am planning to stick it into the S15 shell at this stage, unless a nice SR20DET turns up... For now, i am going to try and get the RB25 running and working well then decide what gearbox to use. My preference is to retain the SR20DET  6 speed gearbox and tail shaft to retain as much and least modifications as i can avoid. I am an old guy and won't be doing any heavy drifting so i don't need a bullet proof gearbox Does anyone have experience with starting the RB on a stand? I got everything setup as much as I can with the info i can find... endless searching and videos on Youtube I would be great to get some pointers Cheers Songo
    • Hey all, Recently have had my s1 r33 gtr serviced and noticed my coolant reservoir was topped up to the max line. Took the car out for 1 yesterday and noticed today the reservoir is completely empty.  Any ideas? Radiator is full
