Yeah ive heard of a lot of A1000's failing
So ill stick to the good ole plain jane Bosch Motorsport pumps
Yeah, better bet than an A0000
I'm just not a fan of multiple pumps.... too much area for undiagnosable failure for me.
I've seen some set ups with 5 or 6 044's.... try and diagnose a failed pump in that lot! ha ha ha ha ha ha ha ha ah.
If they're setup in parallel, that'd be EASY.
Each pump would have a check valve so if it does fail, fuel isn't pumped backwards through the pump.
So between the pump and one way check valve, you'd installa fuel pressure gauge.
Diagnosing which pump is failing isn't hard to do.
    • How dare you sell your unreliable Skyline and buy a reliable, Toyota/Yamaha car with a strong gearbox, torsen LSD and Toyota reliability. At least you won't need to worry about oil pumps, big catch can, oil restrictors, blowing off power steering belts, sheering off 3rd gear, failing ABS relays/pumps, etc.
