Inlet and outlet pipe sizes are three inch.
There is no possible answer to your question. At how much pressure drop ? How much ambient airflow, and what temperature drop through the core ?
It is not possible to say a cooler works very well at 299Kw, and is total crap at 301Kw. It does not work that way.
I have heard a lot of experienced and knowledgeable people say 400 BHP (300Kw)is the point where you should start seriously thinking about something bigger.
At that flow there would be a boost pressure loss of about 4 psi to 4.5psi, that might be o/k, and it might not be.
Hi Abusd, save you the trouble of a PM, we use standard R33/34 GTR intercoolers up to 300 rwkw, over that we use a Greddy 600 X 300 X 115. That's our rule of thumb. BTW we always use tube and fin, never bar and plate.
I have only tested 1 X GTR at 50 lbs of air per minute (enough for around 300 rwkw) and it had 3 psi higher pressure at the turbo outlet than at the plenum, using turbos that were pretty much at their limit. Indicating there was a pressure drop of 3 psi, but not all of that was in the intercooler, some would have been in the pipes, the silicone joiners and the plenum inlet itself. We stuck the Greddy, I mentioned above, on and the car then showed 1.5 psi. So I can only say for certain the intercooler was at least 1.5 psi.
What Warspeed said is right up to a point, the pressure drop increases very fast once you exceed the airflow limit. It might get to 6 psi at 60 lbs (another 60 rwkw) and that's a problem if your turbo is at its limit. If we want more power (much over 300 rwkw), it will most likely be cheaper to upgrade the intercooler than upgrade a pair of turbos.
Hope that helps
Thanks heaps, ive got a GTs-T and thinking of fitting one of these, chasing about 250-270rwkw, me thinks ill get a GTR core!
Do GTR cores come out in bar and plate, or only tube and fin?
Thank you very much for all your help guys!!!
:):):rofl::rofl::cheers::cheers:
  • 3 months later...
sorry to drag this old post up again...
SK et al...
Any reason why the bar and plate is not used ??
Hi Gizmo, as a generalisation, bar and plate reduces the airflow to the radiator, tube and fin cools the charged air better but has slightly more resistance. In a road/circuit car cooling the radiator and the charged air over the race distance is more important than a few horsepower lost as a result of the higher flow resistance.
In a drag car it may well be the other way around, you can't afford any horsepower loss, the engine hardly heats up during the run and neither does the charged air (not compared to a 20 minute race, anyway).
Another of those horses for courses.
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
