hey guys been told by workshop that seals on the turbo of my car may have gone so im thinking of parting the car as long as a deposit is put down for the ENGINE, GEARBOX (manual conversion), computer and coilovers :D SO FOR THE MEANTIME THIS IS AN EXPRESSION OF INTEREST:
car is a 94 model r33, mods include:
- r33 SERIES 2 front end conversion, including immaculate headlights, front bar with foglight/indicators, front bar reo, bonnet- $1000 or complete shell for $2000 :thumbsup:
- r34 rb25det neo motor complete, minus turbo, with approximately 50,000kms (purchased from hills motorsport and still gave receipt)- $1700
- r34 rb25det gearbox with heavy duty clutch (complete manual conversion included) - $1700
- custom GCG garret gt34r turbo kit (wuth suspected blown seals), has travelled less then 5000kms, and never boosted past 15psi. comes with water and oil lines, adaptor plate, and everything needed to bolt on to standard manifold, turbo is slightly larger then the a highflow, and good for 300rwkw. $600
- r33 rb25det Apexi Power fc and handcontroller - $1300
- r34 rb25det neo Deutchwerks 550cc injectors - $400
- HKS evc 3 boost controller (with solenoid and all wiring) - $200
- z32 afm and plus - $180
- Blitz return flow front mount intercooler (some damage but flows fine) - $200
- Blitz DD bov with Blitz hot pipe for r33/34 - $150
- ARC radiator , some bent damage, but tested and hold pressure 100% - $400
- r33 gtst Buddy club Racing spec Coilovers - $1000
- r32 gtr seats, good condition - $450
- r34 gtr wheels with dunlop sp maxx roadworthy tyres - $2000
pm me if interested in any of the parts, or msg me on 0403 558 930
https://www.sau.com.au/forums/topic/336789-r33-with-plenty-of-mods-wrecking/
what else were u planning on paying me with? bananas? and no ive already got interest for the asking price champ. just tryn to sort out the other major bitz before i decide to go ahead with stripping it.
also guys turbo is getn sent away to gcg to get tested :P, as a second opinion said that the turbo seems JUST FINE.
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
