Just running in my stock RB26/30 combo at the mo and starting to get some plans and things together ready for the full map and dyno run.
Can people who have built and/or are running an RB25/30 or RB26/30 using the stock RB30 bottom end internals let me know what boost you are running and what rpm you set your limit to to have a safe, lasting engine? It will be road use 95% probably if that makes any difference. I have read a few opinions just would like some hard facts. Maybe let me know how long you have had your engine running for as well.
Cheers
Lee
just getting myne going atm, planning to rev it to 7-7.5 depending on where it stops making power and gonna be running 20+psi boost. but if you wanna be real safe keep it to 7k rpm and 17-18psi
Well during my run-in tune we only had to rev it to 5800rpm on 17.5psi and that already netted us 297rwkw on the RB30/25 combo (balanced and treated stock bottom end/forged low-comp pistons) with a GT3582BB. Speaking to my engine builder he recommended that my tuner should stick to a mild 6400/6500rpm redline when we re-tune it due to the RB30 crank and rods still being stock items. Plus it's a street car, I don't think that you'd really need to rev it that hard anyway if you're after longevity. I've well and truly ran the motor in now (completed around 8000kms) so it's actually due to go back to my tuners in a few weeks time for more boost and more rpm :) .
6000-6500 on a completely stock bottom end (no extra balancing etc).
run what ever boost it takes to make the power you want (keep the power sensible). its the massive increase in power/revs over stock that kill these engines not lifted heads etc from too much boost.
Thats about the same as I am after leroy
I have rebuilt the bottom end with a bore and new pistons.
Its very easily inside the performance limits of this engine to make 400hp and to rev to 7000.
Im going to go for 18psi or 400hp what ever comes first
waxracing... Are you talking 400rwhp? Gross power that would be easy. A stock RB26 an make that on 1bar. I want to top 500 flywheel and really over 550 if possible but I guess I will just have to wait and see. I want to use as little boost as required.
I think that's a little ambitious. Some say not but if you read the RB30 thread of dyno results you will see very few big hp that are not at least rebored and balanced if not fully forged. I am using the stock (as in original) crank, pistons and rods with a/m rings, bearings and rod bolts and will be limiting revs to 6, 800 and probably using less. I would like to make 500hp but will be happy if I hit 300awkw and anything else will be a bonus. I can't afford to blow my engine so won't be asking tuner to push the limits. BTW I think stock rods are fine - I expect the pistons to be the weak point.
500hp at the motor is roughly 320-330kw at the rear wheels on a manual FR (dependant on drivetrain power loss--normally I go by 15% loss for 6cyl/FR/manual, 20% for 6cyl/FR/auto etc.). I found that formula on some automotive site years ago and been using it as a personal guide ever since. It is not truly accurate by any means but it does gives you an indication of power at the motor.
its all in the tune alrite, i was running a garret 35/40 .82 rear with 560cc injectors (evo's i think) with haltech and 500hp walbro external pump.. it made just over 300kw and was at 17psi.. and lasted 3000kms before detonating and breaking 3 pistons. its bcuz it ran a bit lean after 6000rpm because the fuel pump couldnt handle the jandle. so i suggest u make sure it has a good air and fuel ratio mixture , upgrade anything that needs upgrading for it to run good. that was my mistake :<
my 2c's anyway
Now its forgie time for me baby! :)
guys talk in hp or kw
500hp is 373kw.
Trying to guess loss in the drive train is really not worth it. Just talk in rwhp and your fine.
Unless of course your trying to put your engine on an engine dyno.
The fact that you had deto and blew up shows lack of a decent tune. No engine tuner should have let that car go out with a lack of fuel delivery.
The forged pistons will not stop deto but they will handle it for a bit longer before putting you back in the same situation.
i agree 100% with you and the fact that my engine was left on lean was cuz of limited coin and was a slapper. this next build will be a smarter approach. I HOPE :)
    • Out of curiosity, how do you cover up the inspection hole? Surely it doesn't sit open like that, right? With grime and dirt coming in and oil going out?
    • Hi from Canada, Both of my calipers are starting to fail. My car is a 2005 M35 Stagea ARX and I can't seem to find any parts or any cross reference caliper that would fit my car. Is there a company or a similar caliper that would fit and I could replace the OEM one. Or if anyone knows where I can find a new OEM. Any help is very appreciated. Let me know!
    • Maf is a question mark but TPS  I have set at 0.47, the fact that I’m getting proper voltage range out of it with the key on leads me to believe it’s functioning properly. I’m getting proper voltages on basically everything. I still need to look up voltage ranges for z32 maf and test that
    • Honestly no not at all, but it’s a very basic tune, it’s stock injectors q45 tps and z32 maf. Other than that it’s a completely stock base map. The file is from nistune and from my understanding if it was tune related I would be able to unplug maf and tps and it would still start even if it was a really shitty start. I have tried starting it with coolant temp, maf, and tps unplugged none of those 3 togethor or individually changes anything
    • 🏆 Skyline Supremacy Meets Mount Panorama Magic 🏆 Join SAU NSW as we take the long way to Bathurst, the home of GTR greatness. Saturday 30th August 2025 7:00AM Meeting Hanna Park North Richmond 7:30AM Departure Cruise Via Bells of Line Road 9:00AM Arrival to Stop 1: Golden Poplars Meadow Flat 9:45AM Arrival to Final Destination: Mount Panorama Motor Racing Circuit Meet Location: Hanna Park North Richmond Stop 1: Golden Poplars Meadow Flat Final Destination: Mount Panorama Motor Racing Circuit   *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
