Hi have a few things laying around, need to get rid of these to fund new engine.
1. R32 Rear wing in metallic black Fits R32 ONLY....too wide for 33 - $200
2. R32 3.5inch Stainless Lobster Welded Exhaust, has 3 inch mild steel inlet then goes 3.5 all the way through with single XForce Cannon, excellent condition. $300
Located North Coast NSW
All Offers Considered, Cheers
Pics,
I have absolutely no idea what type it is, fits r32 boot perfectly, looks like 33 gtr wing but its too wide for a 33 boot.
its not on my car atm i just sat it on the boot to see what it would look like.
need this stuff gone $120 wing
$250 exhaust
ono
Edited by DuFFR32
Any chance you can take a pic from the side but further out? so can see what the wing looks like in proportion with the rest of the car
Thanks for the message
I'm about 1 hr north, going away for a week will contact you when I get home and drive down and look.
Cheers Chris
I apologize for my absence on here, went to aus post to see if I can post exhaust but they wont take it cause the front pipe it too long. :P need to find courier any ideas?
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
