I've also posted in the wanted to buy section but does anyone know roughly how much I'd be looking at for a rear left guard?? I was involved in a small low speed accident today and the guard can't be fixed, they need to replace the whole thing.
https://www.sau.com.au/forums/topic/337943-r34-rear-left-quarter-panel/
im having a meeting with a importer tommorrow, and about to organise a RHS 1/4 panel for a coupe, i'm pretty sure he has the other side aswell so i'll let you know.
i was thinking 250-500 but i'll know for sure tommorrow.
it will cost 1-2k to have it installed depending on your panel beater.
d.
Your a few weeks late :laugh: ... Just striped a R34 Sedan had the shell for sale for ages no-one wanted it. Ended up being sent to scarp metal. Would of been perfect for you. Would of saved me calling a tow truck aswell lol. A well guess you'll have to be patient. All the best.
Krysui- Nope wasn't my fault, had a car go in the side of me on the way to uni but the dude hasn't got insurance and I only have 3rd party :laugh: The guy told me he didn't have insurance but went back to his car to 'get a pen and paper' and took off. I was to upset and shaken I didn't think to get his plate number.
I may not need the guard anymore I found a company in Melbourne who can straighten it out without cutting into my car (They heat the panel up slowly and stretch it back into shape)
$375 for a coupe.....
oh i just read llama's comment u have a sedan. mkay back to the drawing board. (thus the edit)
d.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
