ok so i've decided to keep my laurel and use it for a streeter for a while , atm it's running a rb20 with a hks 2530, gtr injectors , z32 , pfc and all the other supporting mods , not being happy with the off boost characteristics i decided to buy a rb25 to slap in the lil 20's place (being a daily driven car , on the street lag can get effing annoying) . Now, before i start pulling it apart, i want to get the complete setup organised so it gets put back together as quickly as possible, so heres a few questions i'd like y'all to give me some input on:
1.) is it possible to use the gtr injectors? , if not , high flowed std injectors?
2.) would the hks 2530 be too small for an rb25 , if so , do you have any other suggestions (keep in mind i'm not after any power figure , just good response/torque)
3.) is the ap engineering pfc adaptable to rb25? (i do have a z32 ecu laying about ready for a nistune board if not)
4.) would a forward facing plenum be worth the cost for this type of setup?
5.) exhaust manifolds , is there any advantage to aftermarket types for lower powered rb25?
6.) is it worth looking for a larger size throttle body?
if there's anything you think i may have missed , feel free to post up . thanks :) (please note: the reason i'm not aiming for big power is because i have a track car to do that with , which is why i'm kinda trying to convert this one as cheap as possible)
if there's anything you think i may have missed , feel free to post up . thanks ;) (please note: the reason i'm not aiming for big power is because i have a track car to do that with , which is why i'm kinda trying to convert this one as cheap as possible)
ok , i spoke with my tuner today and got the answers i needed , incase someone searches for this i'll put up the answers:
1.) no , tightarse, sell them and buy s15(?) 480cc injectors
2.) .64 rear housing (i think it would be) = too small really , i'd be wheezy up top
3.) in short , yes
4.) not if your a tightarse
5.) not with the 2530
6.) i forgot to ask this question :D
It seems if your going to the trouble of RB20 to RB 25, show a bit more "mongrel". After swapping a whole engine go for a better turbo and supporting systems, otherwise just hop up the RB20.
i probably will , the only reason i origionally didn't want to is because i'm building another car with a rb25 t67 and supporting mods , my aim for this car was basically to make it a fun streeter so minimal lag is important :D , i can't think of a better turbo to use for that exact purpose, i'm open to suggestions!
put the 2530 on it and see how it goes. it will give great responce which is what your after. yer sure it'll have f**k all top end and wont make huge power but thats not what your after by the sounds of it. if you dont like it then you can easily remove it and upgrade to something bigger.
as for 6, leave the standard t/b on there with the standard plenum etc
Gt 30/71 or Gt30/76 a little madder and GT 35, or leave in the RB20
gt30 or 35 wouldn't give me the response i'm looking for :D , great turbo's but
yeah that seems like the go , i've searched round these forums a bit but haven't found the answers i'm looking for in reg to turbo sizing , i spend most of my time between 2500rpm and 5000rpm , the problem with the lil rb20 isn't the amount of power it makes but how long it takes to come on full boost (arond 4000rpm i think , pretty similar to my other car when it had a kkr430 strapped to its rb20) . It's my daily atm and i keep catching myself off boost when i really don't want to be, my last daily was a ba xr8 ute so i'm kinds used to large displacement engines too, i don't want/need any more than 200rwk really as i'd only get myself into trouble and a std 25 turbo is smaller afaik , what i'm hoping for is stock like response with a little more mid range :P
as for the tb , yeah , probably too much effort for little - if any gain :)
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
