R33 Gts-t Having Rings/ Pistons Replaced. What Would You Do At Same Time?
A factory motor is more than fine - depending on the application.
Hence if you tell us how much you have to spend, what your intended use of the car is etc etc - people can help rather than just keep throwing ideas around that might not offer you any real benefit at all.
Stock heads are fine, stock bottom ends are also FINE if you only want say 250rwkw.
So why put forged pistons, rods, N1 pumps etc etc spending cash on the head and all sorts of stuff in there?
All you need is a new turbo, dump, injectors, AFM, ECU, clutch etc - That's 5k just there.
Dont forget suspension, most likely some attention to brakes and then suddenly its 7k-8k-9k
Ok, so i'm not going to be racing the car for the forseeable. It's got to be a reliable daily driver firstly, and up to 250rwkw would be more than adequate for my needs for a long time, I'll maybe have $2-3k extra to spend a year on it so I'm not chasing massive power.
So it does seem i'm best saving my money for now and just getting the car back in a running start first eh.
Looking at the brakes will be one of the first things I do though since they don't pull it up quite as well as I thought they should, then start having a good look at anything else that's not been kept on top of maintenance wise. I'm learning more about all the other mods I can do and mostly bolt on, so I'll start making a plan for those things after it's reliable first.
Is it a car yard? Im guessing they will give it a quick hone in the car, new rings and slap it back together. If the piston is damaged, they will only replace one with a factory item(they are $80) Thay really arent obliged to do any more if it is covered by warranty.
It's a yard but they have their own workshop and have been up front about everything so far, they could have just given it to me as is and told me that's how they run etc.
Maybe they will just do that so I guess it depends on what caused that in the first place eh? I'll be asking about the cause too, at this stage i'm more concerned about what else might be stuffed on there. Been trying to read about why they might fail eh, bad oil/ wrong oil/ not enough oil/ overheating/ dirt in the chamber etc.
If it's just one cylinder and they hone it and replace piston/ rings, is that alright?
I think i'll ask for the readings for all 6 cyls and see if they are just gonna do 1 or however many or them all so it's even.
Bollocks, now i'm worried it's been abused a lot and it might be one thing after another...
So is the "rebuilt" stock turbo now containing steel wheels?
No-one would rebuild it and put ceramic wheels back in there.
I would really hope not... I'll ask about that too. Is this obvious/ visible without taking the turbo off completely?
So it's cylinders 1 and 5 that have damaged rings and pistons. Mechanic reckons it's just been overheated at some point.
Would the cylinder numbers indicate a particular problem?
Getting the head checked and fixed next.
What can I do to prevent similar in future... I'm obviously going to take better care than the last guy but given that I live in sunny central Queensland should I be looking at anything to improve the cooling system?
Would it be related to the fact that there could be something wrong with the engine coolling?
Could running an FMIC or R34 GTT SMIC help precent this in future if say I wanted to drive it in a spirited manner occasionally? :-)
a good fuel system is a step in the right direction, as for cooling i never used to get more than couple degrees warmer when giving it some even around the track except when it dropped its coolant out the tell-tale hole when it was parked once. but up to you if you want more piece of mind. if it was 1and6 or 3and4 maybe 1and5 prob nothing in it.
Have you already bought this car? If you've only put a deposit down I would walk away at this point.
Thanks. I'm still puzzled as to how the dude managed to do it if it's not obviously crap getting into the cyinders. Been discussing with someone else and the possibility of it being overboosted at some point is also a consideration.
This has gone through my mind but I'm also thinking if they've had this good a look at the motor then I'll probably have the best history of the car I could hope for and I get something with a rebuilt engine that will last me a good while.
can you tell us the name of the car yard? Pm if you like. If its who I think it is I have a tale to tell you that should have you walking away quick smart!
Lol - you think a car yard trying to sell you an import is going to rebuild an engine that is going to ast you a while considering you're on a tight budget. Lol... Take the advice of people who have been there an done that - walk away from it! Seriously, you dont sound too mechanically inclined or knowledgable so I would walk or run as fast as you can...
Then again, buy it and we'll all have something to shake our heads at when you're back asking similar questions when it let goes in a couple of months time.
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
