1999 R34 Skyline GTV - Non turbo
9 Months Rego
Manual
77,000 kms
Immaculate Condition
Power Steer
Air con
Carbon garnish pillars
Weather shield lips above windows
Factory Floor Mats etc
LSD
Big Brakes 4 pot fronts and 2 pot rears
Front and Rear Strut Braces
Mods:
High Compression 11.8-1 (shaved head)
Adj cam gears
Full Exhaust With Varex Muffler(varible niose levels from remote control)
Haltech Platnium Interceptor with high and low octane maps.
124RWKW
Gates Racing Timing belt and rad hoses
Gab Coilovers
Whiteline 27mm and 19mm Swaybars
Origin Boot lip spoiler
17x9 inch Panasport Rims with brand new Yokohama A-driveR1 tyres
$11500 ono
Please dont waste my time or post if you arent interested in the car...
Located in Sydney NSW
Call Matt on 0415334551
PICS : http://www.carsales.com.au/all-cars/privat...gtv&trecs=1
https://www.sau.com.au/forums/topic/338084-r34-gtv-sydney-p-plate-legal/
  • 1 month later...
    • How do you propose I cable tie this: To something securely? Is it really just a case of finding a couple of holes and ziptying it there so it never goes flying or starts dangling around, more or less? Then run a 1/8 BSP Female to [hose adapter of choice?/AN?] and then the opposing fitting at the bush-into-oil-block end? being the hose-into-realistically likely a 1/8 BSP male) Is this going to provide any real benefit over using a stainless/steel 1/4 to 1/8 BSP reducing bush?
    • ..this is the current state of that port. I appreciate the info help (and the link to the Earls thing @Duncan). Though going by that it seems like 1/4 then BSP'ing it and using a bush may work. I don't know where I'd be remote mounting the pressure sender... to... exactly. I assume the idea here is that any vibration is taken up by the semiflexible/flexible hose itself instead of it leveraging against the block directly. I want to believe a stronger, steel bush/adapter would work, but I don't know if that is engineeringly sound or just wishful thinking given the stupendous implications of a leak/failure in this spot. What are the real world risks of dissimilar metals here? It's a 6061 Aluminum block, and I'm talking brass or steel or SS adapters/things.
