Say i have a forged motor for argument sake a rb26.The motor has a full forged bottom end crank rods pistons and so on.
The kit is pulled out of the block and not marked,
So piston/gudgeon pin/rod are not marked where they came from.Even the rings are in a pile....
Any one offer some insight if this can go back together saftly
Is that a massive head #$%^ and if they don t go back together the correct way is it catasrophic failure time?
Any one shed some light on this as im not a mechanic.
As much detail as possible please.
Edited by Gtir-keiron
Its been running,Pulled apart
My mechanic told me that the gudeion pins have to go back where they come in the same way they came out. from also the pistons have to go back on the rods they came from and so on and so on.
I was planning on doing new rings and bearings but i wanted to know about the other stuff.
My mechanic is anal......Things have to be perfect.. in his world of putting motors together.
just wanted a performance opinon.
Your mechanic is a guy who is trying to pose as someone who knows what he is doing.
Linish pins, resize and balance conrods as well as balance pistons and it doesnt matter what is what. As when they are balanced the piston and pin are matched to avoid taking too much off the piston. If you had a light piston and pin matched together you would have to grind excessive material off all the other pistons to get them to match up.
Someone who suggests putting an engine together without doing this clearly has no idea. Id say you grab your gear and go elsewhere mate.
A quick look at the early failure poll thread will show that there are a lot of guys who take on RB's without the experience with the poor customer footing the bill. Ive screwed together quite a few engines in my time but when i opted for a big dollar bill i went to the experts so the job was done right.
Edited by Supa Steve
Oh thats not what im saying.
Im saying he wants to know what gudeon pin came out of what piston and what rods it was connected to and what order the pistons were in.
Like i said hes anal about things when it comes to building motors.Hes a very good mechanic with alot of exp with RB Sr and nissan engines but sometimes i feel hes over the top and i don t want to spend money where i don t need too.
he already said i would have to replace the rings and bearing and i new that from the start.
Thats why im asking what my options are.
If i can get it all balanced and set up to as new or better then it should not be a problem yes?
thats why i wanted detailed infomation so i had options rather then him telling me i need to replace pistons and pins and things like that.
i think you may have missed it so i will put it a bit more direct.
it means 3/5th's of f*ck all where what came from except for the rod caps which are generally numbered and anyone who tries to tell you otherwise is giving you incorrect information. Clean everything up and weight-match to ensure best clearance and minimum grinding of pistons. Rods NEED to be resized and balanced to ensure they are exact. If he is as pedantic as you state then this should be a given for him to understand. Pistons and pins will only need replacing if the pin has flogged out the bore of the pistons and/or bent the pins.
properly prepped and assembled serviceable parts will have your engine as good as new.
best of luck
As steve said, everything can be measured to confirm where it goes, however if there is no discernable difference when measuring, then it doesnt matter where they go. Then check balance and assemble.
    • Price seems pretty good to me. Also seems a hell of a lot cheaper then buying another vehicle that only ever gets used for towing.  I'm a long way from you mate, I'm a couple of hours out of Brizzy.
    • New [400]Z, they're available in manual and you don't have to worry about parts scarcity.
    • Just planning to have the wiring neat and hide as much as possible.
    • The sodium acetate, mixed with citric acid, doesn't actually buffer each other. Interestingly though, if you used Sodium Acetate, and acetic acid, THAT becomes a buffer solution. Additionally, a weak acid that can attack a metal, is still a weak acid that can attack a metal. If you don't neutralise it, and wash it off, it's going to be able to keep attacking. It works the same way when battery acid dries, get that stuff somewhere, and then it gets wet, and off it goes again breaking things down. There's a reason why people prefer a weak acid, and it's because they want TIME to be able to be on their side. IE, DIY guys are happy to leave some mild steel in vinegar for 24 hours to get mill scale off. However, if you want to do it chemically in industry, you grab the muriatic acid. If you want to do it quicker at home, go for the acetic acid if you don't want muriatic around. At the end of the day, look at the above thumbnail, as it proves what I said in the earlier post, you can clean that fuel tank up all you want with the solution, but the rust that has now been removed was once the metal of the fuel tank. So how thin in spots is your fuel tank getting? If the magazine on the left, is the actual same magazine as on the right, you'll notice it even introduces more holes... Well, rust removal in general actually does that. The fuel tank isn't very thick. So, I'll state again, look to replace the tank, replace the fuel hanger, and pump, work out how the rust and shit is making it past the fuel filter, and getting into the injectors. That is the real problem. If the fuel filter were doing its job, the injectors wouldn't be blocked.
    • Despite having minimal clothing because of the hot weather right now, I did have rubber gloves and safety glasses on just in-case for most of the time. Yes, I was scrubbing with my gloves on before, but brushing with a brush removes the remaining rust. To neutralize, I was thinking distilled water and baking soda, or do you think that would be overkill?
