Hi there, I've bought an R33 GTR with a single turbo conversion. Its a monster, and its pushing 275rwkw at 15psi; when tuning it they increased the pressure to 17psi and it pushed well over 300rwkw, but they wound it back to 15psi because they said the stock head gasket wouldn't handle it and I need to replace it, the pistons, and conrods before looking at the injectors and fuel rail. I was under the impression the stock internals would be good for up to 600hp; are the forged or not? how much psi can the head reasonably take? I'm sure there is a thread on here somewhere about this but I can't find it, so would be very appreciative if someone could give me some answers.
Well the internals aren't forged so 600hp might be a bit much.
But I don't see why you could upgrade injectors computer and fuel pump and go for 300-330 rwkw?
Just note I'm no expert so don't rely on what I say :P
Edited by gtr fan
Thanks for that; I'd be happy with 450hp. It already made over 300rwkw with stock injectors and pump, and has power fc commander, my mechanic is telling me the head and internals are the limiting factor and I'm starting to wonder if they are trying to generate some business for themselves. It would be great if I could just add a few more pounds without spending big $$.
Leave it as is until you have the money to go for a rebuild ($10k +).
If you want to run big power, realiably you will need some big cash to go with it. The wagon in my avatar had 500rwhp, its still going today. It cost around $15k to put together.
Thanks, I guess I'll just enjoy it as it is. It's a shame though, as the turbo the last guy put in it (only just run in- I removed the rev limiter) was chosen for a 500hp setup. It's not very efficient running such a large turbo at low boost right? Is there any other reason that may justify me doing a rebuild?
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
