gday guys got a few things for sale need em gone asap
2x autometer gauges 60mm boost and oilpressure great condition $80 each
R33 gtst front brakes comes with rotors and calipers $220 ono
MOMO steering wheel with r33 boss kit comes with spare steering colum n keys $150
R33 gtst series 1 seats front pair only tiny tear in drivers seat which is common $200 ono
R33 gtst series 1 auto gtst ecu $100 ono
stock smic r33 gtst $50 ono
JL AUDIO 500/1 mono block amp bought from jb hifi for 1200 wanting $400
Rated Power: 500 W RMS @ 1.5 ohm - 4 ohm (11V-14.5V) THD at Rated Power: <0.05% @ 4 ohm S/N Ratio: >95dB below rated power (A-weighted, 20 Hz - 20 kHz noise bandwidth) Frequency Response: 5 Hz - 250 Hz (+0, -1dB) Damping Factor: >500 @ 4 ohm / 50 Hz
>250 @ 2 ohm / 50 Hz Input Range: Switchable from 200mV-2V RMS to 800mV-8V RMS Dimensions (L x W x H): 13.40 in. x 9.25 in. x 2.36 in.
340 mm x 235 mm x 60 mm
hks hyper drag coilovers front n rear r33 gtst/gtr great condition only 5000kms old $1200 ono feel free to pm me but rather text message as ill be able to reply straight away 0428819885 WILLILN TO SWAP ITEMS FOR OTHER ITEMS LIKE PILLAR MOUNT FOR GAUGES, STOCK WHEELS to suit R33, LSD or SINGLE SPINNER DIFF TO SUIT R33
Takin offers on all items , will swap for tri pod mount for gauges LSD or single spinner diff to suit r33 also looking for stockies to suit r33 come on guys make a offer
goin to pick up a diff tomorrow any one keen to swap items for n e thing i have listed after a triple gauge pod
May also be selling a 35/40 turbo perfect condition external gate .83 rear housing only done 300km might be downgrading to something smaller as i dont want to much power only 250-280rwkw
would you swap for my lcd/dvd single din head unit with cash ontop?
its in the for sale section.
if not maybe a replica sparco bucket seat with maybe some cash on top?
for the amp!
located in melbourne south east also got
3x auto meter cobolt series gauges
BOOST , AIR FUEL , OIL PRESSURE , boost has its own black cup the other 2 are in a made up bit of metal that sits under the headunit of a r33 or r32 80 each for the gauges perfect condition
will swap parts for a mines or tuned r33 series 1 ecu
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
    • Yeah that looks like great caster, but I'd suggest trying less front camber some time and seeing if it helps with braking without reducing mid corner speed too much
    • I ended up setting the rear 5mm higher than normal to give some clearance.  My plan is to run the least camber I can in the rear which I think with the extra width is going to need to be -1.75 to -2.00° just to get clearance.  Guards have been rolled and pulled as much as they can/I would be wanting to.  front has the Acostal knuckle with the KPI change and the drop etc. So should be okay with the existing settings I have run with AR1s etc Front: Toe total -2mm(1mm out each side) Caster +7.5° Camber -3.8° Ackerman +15°
