  • 3 weeks later...
couple of images of the modified cluster: (this is V1 - I'm not happy with how it came out.)
I had these done locally:
that entire panel (where the cruise indicator sits) has been redone. there is one issue with it. the security indicator
is inverted. it was supposed to be a red background with black text. a stupidly bright white LED lights it up. (I have a LED drop light under it for this shot.)
I am going to take it back to the people that made it for me and get the security area redone so it matches the rest of the panel.
at the moment its a bit hard to see unless you are on top of it.
this part came up ok apart from the inverted lower panel.
LCD panel in place. this is also V1. it needs to come up about 2-3 mm and the entire panel squared up.
this was done with a hand saw and looks a bit rough for my liking. again something I intend to take up with the
people that did it.
more to come. the interface and harnessing is next up.
yep. most of the electronics is getting done at the moment. my goal is to get the cluster done again and from there the switching,rev cam, HKS unit and navi harnesses.
ok started V2 of the dash.
V2 entails totally removing any evidence of the tach even being there.
started looking at it this morning and I reckon I can make a insert to fit on top , high fill,sand,chamfer and make it look like this:
(yes this is a nismo 33 item - concept is what I am going for. note chamfered edges around the screen)
so it looks like I will need another 32 cluster to work with..
(if you know of one - tell me.)
just put a request in for a set of N1 headlights, new from indicators,
purchased a new set of door catches (they were cheap!)
the catches should be here in a couple of weeks. they are part of a much larger shop order.
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
