I was under the back of my car last night and noticed that the diff/moustache bar moves up and down on the chassis mounts.
Moves about 20mm is that normal? Car seems really soft and floaty on the road, has mega body roll too.
Can I use bushes from other dattos for the front end/swaybars local parts place doesn't list much for the C210
Cheers Dan
https://www.sau.com.au/forums/topic/339935-c210-diff-movement/
Dan,
Your front sway bar mount rubbers will be same as R30, Tension bar bushes will depend on diameter, but I think same. Sway bar end/link pin bushes are all same. Pedders have a beaut pin, it has a flat in the centre of it so eack end can be tightened separately and can be bought in varying lengths.
As for your rear end float: No it's not normal and it shouldn't be there. Tighten the nuts or maybe the bushes are stuffed, so they might have to be replaced.
If you cant do any good, PM me and I'll try to organise them in Sydney and post them to you.
Cheers, D
Ok, so far I've found.....listed for a c210
Rear swaybar link kit. (is the front link the same?) same P/No. as R30
Tension bar kit. same P/No. as R30
Still need front and rear swaybar D-bushes (can anyone confirm there the same as R30) Front bar 21mm/rear bar 18mm
and what about front/rear control arm bushes?
cheers
My bushes are shot too (moustash bar)
Can you let me know where to get em? every time I touch the accelerator it goes Boom, and the same on de-celeration. so bloody annoying when cruising at 100km/h, bom bom bom as im feathering the speed.... arrtghhh
if you are in the business, maybe get some solid ones made from metal? a few race setups use them. would transmit a fair bit of vibration throught the body though.
Babalouie: Thanks man, that's exactly what mine looks like/is doing will pull the bar off tonight and press the bushes out at work tomorrow.
MAG86: I don't know about making steel bushes we have this delrin plastic but that probably wouldn't be much different then the steel ones. Depends how much there going to cost I suppose.
wow,
Have your wheat bix before trying to get those studs out the back of your diff. Will defiantly be putting bolts back in on re-assembly. Pulled the sway bar while I was under there, bushes are well and truly shagged.
do your lower control arm inner bushes (front), and ball joints, sway bar link bushes, i did them and the steering is much more soft to turn now. (non power steering) while you're there grease up all the steering links.
Stewart wilkons motorsport for the moustache bar bushes and nolathane for the D bushes .
JFYI Stewart Wilkins gets his bushes from Whiteline Plus, a subsidury now of Nolathane up Sommerset way. (Wyong) He has a front caster bar kit that comes with oversize od crush tube and it's blue and used to come from Noltec before they were gobbled up by Nolathane. aka Redranger.
D
If your going to do your moustache bar bushes, maybe at same time you might want to think about the rear crossmember bushes, because they now do this bush off the shelf after much pioneering by myself and a couple of others getting them custom made by Noltec when they were at Thornleigh.
Note the date on the picture, but they were made in 2002 at about $460.00 pair.
You will find they eliminate sh!tloads of rear movement.
When your looking at pivot point bushes such as rear trailing arms and inner lower control arms, take a page out of the rally boys book and stick to bonded rubber unless of course you want to be changing them about anually.
Cheers, D
When I said Swmotorsport I ment that's where I got them from not who makes them. I got the rear D bushes from a local brakepro under car, he had them in stock :D
Mate, have those cross member bushes come down in price any since then? Bit out of my budget at the moment.
You wouldn't have a pic of them out of the car by any chance?
Cheers Dan
Edited by harvo
A mate of mine recommended this as an alternative to changing the subframe mounts. You modify the bell-shaped washer locating the bottom of the subframe bush to squash up the rubber mount to reduce movement.
http://www.the510realm.com/viewtopic.php?f...73&p=143439
I figure as long as your bushes aren't totally gone, this should help.
    • LOL.... a good amount of people (not all) on that continent seem to know everything and like to measure things in bananas, football fields, statue of liberties instead of the metric system lol.
    • I assume the modules are similar enough, so if you've had no issues I don't see why I would. I have tried to find a wiring diagram for the FPCM / fuel pump circuit, but I can't find it anywhere. Otherwise, I would just do some wire cutting and joining at the FPCM and give the 12 V supplied to the FPCM directly to the pump instead. If you know anyone that could help with wiring diagrams, I'd be very happy
    • If it dies, then bypass. The task isn't difficult. I have one running on a standard R32 FPCM. That's after nearly 20 years of it running an 040, which pull substantially more current than the Walbro. They're not the same module, but I'd hope it indicates that the R33 one should be man enough for the job. I think people kill them when putting proper sized pumps on them, not these little toy pumps we're talking about here.
    • Silicone spray won't hurt anything. And if it does, that's an opportunity to put some solid steel spherical bushings in, so you can really learn what suspension noise sounds like, If you're going to try it, just spray one bush at a time, so you can work out which one is actually noisy. My best guess is that if the noise started only since putting the coilovers in, then it is just noise being transmitted up through the top mounts of the struts, and not necessarily "new" noise from bushes. But it's almost impossible to know.
    • Are you saying the 34 is SUV height, and not that we're talking about an SUV here? (because if we're talking about an SUV, you don't fix them. You just replace them when something breaks. Not worth establishing sufficient emotional connection with an SUV to warrant doing any work on one). I wouldn't jack my car up on a short little loop of 10mm steel rod poking out through a hole in the bumper bar, front or rear end. I realise that we're probably not talking about that type of loop at the front, being the one under/behind the bar on a Skyline.... but even for that one, trying to jack up on what amounts to a thin piece of steel, designed purely for withstanding a horizontal tension force, not a vertical compressive force (and so would be prone to buckling/crushing) and, my most particular bitch about it - located RIGHT AT THE EXTREME FRONT OF THE CAR, applying a load up through the radiator support panel, etc, with almost the entire mass of the car cantilevered between there and the rear wheels? Nope. Not doing that. Not on the regular. That structure out there in front of the front crossmember is not designed to carry load in the vertical direction. Not really designed to carry any load at all, really. The chassis rail that the tow point is connected to would be fine loaded in tension, as per towing. Not intended to carry the mass of the whole car, especially loaded all on one rail, with twisting and all sorts of shitty load distribution going on. No, I will happily drive up on some pieces of wood, thanks. That can only happen on driven wheels, and they are at the other end of the car, and this problem does not exist at that end of the car. And even then, I have been known to drive up on at least 1x piece of 2x8 each side at the rear, simply to reduce the amount of jack pumping necessary to get the car up high enough for the jack stands. What really really shits me about Skylines is the lack of decent places for chassis stands at either end of the car. You'd think they'd be designed into the crossmembers.
