Full R33 series 1 interior incl door trims front and rear, Front seats, Rear seat and Rails all in immaculate condition....only $500 NOT NEGOTIABLE
R33 Bonnet black paint excellent cond. $200
Apexi boost gauge current series with white face.$150
No room available so fairly urgent sale required if someone is interested in the whole package can take it all for only $700 and ill throw in a set of NISMO clear indicator lenses for R33 aswell.
Anthony 0404 297 426 Leave Message and ill get back to u...Cheers
https://www.sau.com.au/forums/topic/33997-r33-cheap-parts/
  • 4 months later...
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
