Full R33 series 1 interior incl door trims front and rear, Front seats, Rear seat and Rails all in immaculate condition....only $500 NOT NEGOTIABLE
R33 Bonnet black paint excellent cond. $200
Apexi boost gauge current series with white face.$150
No room available so fairly urgent sale required if someone is interested in the whole package can take it all for only $700 and ill throw in a set of NISMO clear indicator lenses for R33 aswell.
Anthony 0404 297 426 Leave Message and ill get back to u...Cheers
https://www.sau.com.au/forums/topic/33997-r33-cheap-parts/
  • 4 months later...
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
