hey everyone.. thought maybe someone on here could shed some light on this for me since theres not much info on the net... trying to connect to computer but it keeps saying " no connection to ecu" .. on the website it says win 95 , 98 and 2000.... is this problem because im using windows 7?? thankyou
comm port uses usb cable
u mean it uses usb drivers? if so ok ill try and update.. if not im confused...
getting drivers form the asus website would be better then using microsoft ones hey??
seems i am up to date... wat a pos...
Edited by BrynDETT
u need the usb driver that came with the microsoft software, windows 7 is a pain in the butt and if you connected the ecu and tried to connect without the correct usb driver than your up shit creek and gonna have a hard time getting it to work, sorry to be the bearer of bad news but i had the same issue with the Vi-pec software, i had to use the older usb driver that Vi-pec had.
im not sure with mi-corrects but do they have a serial cable coming out then the microsoft adaptor converts it to usb so that you can connect it to the commport of the laptop???
hmmm thanks for ur help jez... im just gunna give up on this laptop idea and go buy a handcontroller... only wanted to take some fuel out of it so i could let it idle and bleed the coolent system... thankyou anyway mate
and yeah it has a serial cable 9 pin.. then u have to buy the microtech laptop dongle thing then plug it in the a serial port... well thats the way i had it set up
Edited by BrynDETT
k spewin, you could try calling microtech efi technical support but GOODLUCK with that, thats were microtech get all there good reps for beeing able to help and giving you a straight answer :D
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
