Hey all,
I recently bought a Stagea NM35. One thing that annoys me is the sequential shifter style. As stock, you push up to change up gears and push down to change down gears. But this I find uncomfortable and seems against the cars motion when accelerating hard or braking hard. To me (IMO) it makes more sense to push up to shift down gears (as your leaning forward when you brake hard) and pull down to shift up gears (as your being pushed back into seat when accelerating).
I thought before I go ripping out the center console to see the possibility I'd check to see if anyone else has done this already and what they did. Also if anyone has some kind of schematics would be awesome (although if lucky its just simple wiring). I can see myself soon opening it up to see the circuitry underneath to make the change.
Cheers!
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
