]mines actually on +5 on idle...(auto) and jumps to 20 when i rev out its a mechanical cobalt series boost/vac gauge i just tap'd it into the line at the front of the manifold like described in a step by step posted on here i know its wrong coz my stock gauge sits in the - and jumps accordingly.. post-84025-0-70170300-1306822304_thumb.jpg
Edited by nismo07
any idea's?
Hmm, not sure. I've always tapped boost gauges directly off the plenum itself. Never really tried to tee it off an existing line. It definitely should be reading somewhere in the negatives on idle though.
Edited by GT32
Was thinking maby trying it at the rear where the stock line goes in from the little box right near the brake booster? if i was to pull that off and run the gauge straight in be fine right? doesnt matter if i disconnect the stock gauge at all does it??
Hmm, you could be right. Possibly a faulty gauge. I used to have an Omori boost gauge on my old 32. The gauge looked ancient! Was a mechanical type and I remember it was always 1-2psi out. When I had the car dynoed a few years ago, their dyno chart always displayed 1-2psi higher than what the boost gauge in the cabin displayed. It was probably due to wear and tear though. Is the gauge you're using brand new or second hand?
Brand new from autobarn was a cobalt autometer so thought it was quality rofl...
Hmm, could be faulty. Bring it back and exchange it for another one to see if it still does the same thing. I'm not even gonna bother using a conventional boost gauge this time around in my new car. Once my AVC-R goes in then I'll just rely on that from now on to show me how much boost I'm running. :).
also shouldnt the gauge reset to 0 when the ignition is off? it sits on 15+ ??
Sorry, didn't see this. Yes it should revert back to +-0 when the ignition is off. If it sits on +15 then there definitely is a problem lol.
definitely was the gauge lol... funny on the phone to them were trying to blame installation but once they actually looked at it they said "yea its stuffed"... lol dont know how it could be my fault when the needle resets to +15psi and wont go below 5+ anyways yea overnight delivery :)
kool on another note what should the boost be reading on idle?? -7 like the stock gauge?
Different units, the stock gauge reads in mmHg x100 for both positive & negative pressure.
Most aftermarket boost gauge will read in inHg for negative & either PSI or Bar for positive pressure.
15 - 20 inHg is the norm for idling pressure with the car stationary, anything lower than 15 inHg & you may have a leak somewhere.
    • (it is a brand new ported mellings pump) I suspect the lack of pressure is due to the leak. It was *not* that low in other logs of oil pressure in the past. It wasn't that hot either, but not far off.
    • Would a Mellings oil pump be a viable option  From my time with a LS, and talking to tuners and LS specialists, the "weak" OEM oil pump is one of the first things they recommend to swap out if I was going to give the engine any high RPM I opted for a Mellings high volume, with the high pressure springs and I never had a issue with it Cost wise they are not expensive in the scheme of things
    • Just bought a 2002 Stagea 250tRS VR-X Four AERO VQ25DET and spent the last two weekends cleaning and detailing it.. still have to do the wheels and the engine bay but the rest of it came up nice. Imported 2011 to S.A. and I'm the third owner since it was imported. I met the guy who brought it over, he went to Japan and picked out the car, bought it and ordered the wheels. He also gave me a list of stuff he did to the car with receipts. Coil overs (I have the original springs), 3" exhaust from the dump pipe back no cat, Custom dump pipe,(I have the original exhaust), Plenum spacer, 18" custom Work XSA wheels (need restoring, I've made a start..), Shift kit put through the 5 speed tiptronic auto, TV and menus/screens changed to english, Australian DTV tuner installed in rear. I've just had four new discs and new pads as well as all the fluids including the brake fluid replaced. I have all the receipts for the last 15 years and the import papers in a nice folder. Car looks great, goes like hell but fuel economy is not a thing lol.. pics next..
    • I ended up in this rut again lol, and used a shit ton of filler. One thing I can't understand is, even after using a big long block and going in long X pattern strokes, I always end up at bare metal again with no filler, and my repair started at one end of the door and now I've chased my tail to almost the other end of the door. I was thinking of hitting the panel with a hammer where it might be a high spot and making everything low then filling it, I did this on a small section on my other door by mistake and I think I fixed it lol. Is this a bad idea? The other thing is with guidecoat, whether it's the powder or spray, after I sand all the guide coat off, it doesn't reveal anything for me in terms of high spots and low spots and makes it especially hard when it's bare metal (at least in powdered form), am I doing something wrong here, or likely a high spot I keep going over and creating valleys? Lastly, stupid question but, is it possible that after sanding if I only sand over the filler area where I know to be a dent that it's impossible for me to dig into that dent? Unless there are other problems which I missed.
