Hey forum just a general knowledge question here. I used the search function, but found no topics on the subject. I just would like to know what effect what a machined 3076r comp housing have on a gt35r?
Faster spool, slower spool, same spool, less horsepower at same boost or same horsepower at same boost?
https://www.sau.com.au/forums/topic/340336-effect-of-smaller-comp-housing/
think i read a while ago from someone of the xr6t persuasian that swapping from .5 to .7 on a gt35 is worth 20 or 40 kw in the top end or someting, not a massive amount... i'd imagine spool would be effected relatively proportional to power
Hmmm so where would the .6 get you? Would you still have the top end capability of a 35r with a somewhat quicker spool time? Or would the effect be negligible? Would it still make more power than a 3076r of the same specs?
That hybrid 35r would prob make better powar than a 3076r, purely because it's got the larger rear, and less exhaust restriction.
I'd say response would be the same, the comp. wheel's inertia is the same, and the hot side is unchanged.
However you'd probably make more/better power at lower boost levels, and I'd imagine less power at higher boost levels.
i.e. it would move the efficiency range of the turbo down a tad.
think of it like installing a smaller profile camshaft, just makes different power at different revs.
that's my $0.02...
It wouldn't work because the inducer diameter of the 82mm GT40 56T compressor wheel is larger than the 76.2mm GT37 56T wheel . From memory the GT40's inducer is ~ 61mm where the GT37's is ~ 57mm . The compressor housing on a real GT3076R is port shrouded and the radial surge slot is positioned to match the height of the GT37 wheels lower or splitter blades . It wouldn't be right for the GT40 wheel and I'm not sure if there is enough material in the inner shroud to take a GT40 compressor .
The early XR6 turbos used a 0.50 A/R plain snouted T04E compressor housing and I can't see why you couldn't fit the plain snouted 0.60 A/R version of that housing if it was profile machined to suit the compressor wheel .
To me it sounded like Ford only wanted to run low boost on the early XR6's and having a GT3582R with the largest turbine housing and the small ratio T04E comp housing would have given them low hot side pressure and reasonable gas speed on the cold side with low boost pressure .
It really shouldn't be too hard to get good torque out of a twin cam 24v 4L turbo engine but as usual you can't choke it up on the hot side if you want a reasonable rev range - and reliability .
Personally I think a GT35 based turbo is a bit marginal on a four litre engine and a T04Z or GT4088R would have been better , trouble is they don't have a "T3" mounting flange or an integral waste gate .
Garrett do make a port shrouded version of the 0.70 A/R T04S compressor housing , the generic GT3582R usually gets the plain snouted bell mouthed version of it .
http://www.turbobygarrett.com/turbobygarre...R_714568_10.htm
A .
Edited by discopotato03
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
