Rb26 standard dumps $50
Rb26 standard turbos one is blown $200
Rb26 standard exhaust manifolds $50
Potenza semi slicks 195 15" x2 on 4x100 maybe 50% tred $ 180
Rb26 standard rods $120
rb26 flywheel and used but still has life exedy heavy duty clutch $300
make offers must go
https://www.sau.com.au/forums/topic/340353-rb26-parts/#findComment-5503274
also AFM's (pair) for sale rb26 $200
https://www.sau.com.au/forums/topic/340353-rb26-parts/#findComment-5522860
  • 3 weeks later...
  • 4 weeks later...
  • 4 weeks later...
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
