currently have an 1995 r33 GTS-T with full 3inch exhaust system. front mount. pod filter.JJR plenum. I wanna know where to go from there
Injectors,fuel pump,fuel reg and power fc? splitfire coil packs? im not after hectic amounts of power. only want to spend around 2500. max $3000.
https://www.sau.com.au/forums/topic/340759-r33-gts-t/
search the forced induction section mate, absolutely tons of info there.
Try this thread and then go from there:
http://www.skylinesaustralia.com/forums/Fo...ick-t66556.html
With your budget, i'd do fuel pump to be safe (bosch 040), power fc and tune (you should get about 200rwkw). Injectors, fuel reg are useless for your needs, coil packs MAY need upgrading depending on the condition of your current ones. Make sure the car is well serviced, and you put some decent tyres/brakes/suspension on it too :blush:
https://www.sau.com.au/forums/topic/340759-r33-gts-t/#findComment-5500768
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
