P PLATE LEGAL TURBO! Mitsubishi Galant Vr-4 91’ For sale
This is what has been done to it.
The body has done 230000KM
I am looking for 7500
ENGINE FULLY REBUILT 3500km ago.
ACL Race Top and bottom engine bearings
RS Pistons and Rods
All Brand new Gaskets
Heavy duty Exedy Clutch 9 PUK 3500km old
Full 3 “ turbo back Exhaust
VAREX Muffler (controllable valve)
BC BR Coil over’s
Ostrich ECU chip
Palm Logger
EVO MAF
All Wiring done for a subwoofer and amp.
Pod Filter and shortened intake
Upgraded Intercooler.
Brand New Top Gun Leads
All Belts including timing belt done 3500km ago
Brand New Water Pump
Refurbished Gearbox
16G Rear housing of turbo.
EVO MAF
The interior is immaculate, and the body has been kept in excellent condition for its age.
Contact 0432358969 or Pm Me on SAU
The best part about this Galant, is that it is P plate legal. So if your looking to drive a turbo car on your p’s look no further! I have an exemption which i will gladly pass onto the new buyer. (Dont ask me 101 questions about the exemption and how you can get it for another car, because this is unique to this particular car!)
Edited by lanka05
I dont understand how you can "pass" the exemption onto the new buyer. A exemption is specific to an individual NOT the car it self...
Sorry mate, The new buyer will need to apply for the exemption. He/she can do it before purchasing the car.
Then don't provide false information.
You cannot pass on an exemption.
So it's NOT P-plate legal!
You need to be approved for an exemption. No different to any other turbo car, for P-platers. And they don't hand out these exemptions to anyone, you MUST have a special reason why you need to drive "high-powered" cars. ie: work related, etc.
    • Yeah I've had too many issues with knock off's on the BMW's. I don't want to do a job twice or more because the parts are shit.
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
