I've not been past Kambah to have a looky, but Pat checked out Nicholls (northside servo) not long ago, and they said there was an engineer out there checking out the pumps to make sure it'll be all good.
Exactly. Haven't plenty of people including Trent (STATUS) mentioned you won't gain any more power past a certain point of ign timing on an E85 mix anyway? If you're running it in a street car, particularly a daily like mine, conservative tuning is the way to go. Go close to the edge with 98 mix, then back off the timing (particularly up top) and add a touch of fuel. Would rather feel the torque from E85 than see what kind of top end figure I can pull.
ill have to check a few things about it problem with my setup (apart from the need for additional pumps) is my 1000cc wont cut it lol would be fun to have a gt42 on street tuned 30psi though haha not sure if the motor will last too long though haha
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
