I had this Kakimoto system on my own GT-R for some time and chose it for it's excellent quality and ability to keep noise in check. Truth is though I drive my R33 so little I can afford to have it obnoxiously loud so I've switched out to a ridiculously loud Apexi system now.
This system is, as you can see, still as shiny looking as the day I bolted it up.
New price is $1100 + shipping for this but I am only after $700 for mine.
SOLD!
More photos:
http://www.nismo35.com/images/kakimoto-06nr-02.jpg
http://www.nismo35.com/images/kakimoto-06nr-03.jpg
http://www.nismo35.com/images/kakimoto-06nr-04.jpg
Fitted up to my car:
http://www.nismo35.com/images/DSC_0097.JPG
http://www.nismo35.com/images/DSC_0101.JPG
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
