5x114.3, 17 x 9 +17
in pretty orrite condish, some paint bubbling in the centre from heat build up, which isnt noticeable until youre pretty close. and 1 of the wheels has a 15ish cm of rash on it, not hella hardcore, but its there. probably clean it up a bit and give it a quick lick of black paint. problem solved.
comes with 225/45/17 kumho KU36's all round, rears are getting pretty haggard, and theyll need replacin sometime soon.
fronts are about 1000ish kays old, cant see the lettering in the centre rib anymore, plenty of driving left in em.
sit pretty f**kin good on an s14, and would be pretty orrite a 33/34. suit a 32 GTR pretty orrite too. be primo on an s13.
ill get more pics up soon.
and, theyll clear brembos with a small (3mm) spacer. bonus!
chasin $1400.
shoot me a message on here or on 0408961657.
cheers, dave.
https://www.sau.com.au/forums/topic/341146-get-your-murder-on/
f**kin bump!
basically, ive found the wheels i want. someone needs to buy these now.
theyll be supplied with the worn '36's, and (2x) 215/40/17 Pirelli Dragons and (2x) 205/50/17 Pirelli P7's all with over 70% tread within a few days of sale.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
