im just planning on running a switch on mine, not going to have sensors hooked up or anything.
its in a pure track car, will this b alot easier to wire up being that it shouldnt requir a sender ect?
yeah in a pure track car you wont need the controller I have. Cheapest way would be having a water temp gauge/display and turn on the fan when required, but you wouldnt like to forget cause the temperatures will shoot straight up. You are better off just getting a simple temperature trigger controller. You can pick them up for under $50 etc
i have a davies craig set-up with this controller and wondering if i can hook up a manual override aswell?post-69586-1288853394_thumb.jpg
Better off contacting Davies Craig and see if they can get back with any information. The easiest way would be to wire up a relay with a switch on the dash to trigger 12v power to the fans.
cheers mate, great help
  • 4 months later...
im currently in the process of a few cooling upgradeson my cefiro drift car.
got an ISC 52mm rad and a brand new AU thermo setup, but the shroud is too thick, and hits the power steering pump pulley.
i cant slide it down to position at all.
i have exactly 6.5cm room between rad and nut on the pulley, and the shroud is 7cm... im not just sure if i can trim it thinner seeing as the fan hub is also 7cm...
it all comes down to where the shroud is positioned rlative to the pulley nut i suppsose lol
ffs nothing it easy :domokun:
IF you want the best
Thermo Fans CFM Hight (MM) Wide (MM) Depth (MM)
Derale Cooling Products 13" TWN pn:16928 4000 351 723 81 211.95
Derale Cooling Products 13" TWN pn:16934 4000 400 796 82 214.95
Derale Cooling Products 13" TWN pn:16028 4000 351 723 81 334.95
Derale Cooling Products 13" TWN pn:16027 4000 457 660 95.25 $369.95
4000CFM to give you a idea of power a AU is 2400-2600
http://www.summitracing.com/search/Department/Cooling-Heating/Section/Fans/?Ns=Rank%7cAsc
This site has many brands and so on you can pick fom with CFM ratings and so on SPAL is good recommended by PWR
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
    • Hi all,I already introduced myself in the Victoria section, but only saw this section now lol XD New to forums and new to skylines. Hoping to buy my new skyline within October
