Hey
I am going to get the GTR an after-market ECU, but I have found many varying opinions, so I wont be suprised if I get the same outcome here, but I am interested in what people (that are enthusiests) would recommend, so I ask you, what brand ECU would you recommend for my 96 R33 GTR. I have found that Advan Performance recommend the Link ECU, http://www.linkecu.com/ , and I have also been told by others to stay away from the Haltec Platinum Pro, do you concur, or do you have another opinion or other ECU recommendation?
Thankyou
Denis
Edited by den15b
https://www.sau.com.au/forums/topic/341866-ecu-recomendations-for-96-r33-gtr/
talk to the place where you are going to get it tuned. what they prefer to use is going to be the best option as they will be able to do the best tune on that ecu compared to a different one. the tuners knowledge of the ecu is more important that the type of ecu you get as that will determine the quality of the tune when it comes down to the finer details.
Really it is three main brand choices these days that most people go for in RB's as a plug and play full replacement ECU:
Vipec V44/V88 - Link G4
Power FC (Normal or D Jetro)
Haltech Platinum Pro/E11V2
As said by Marc, speak to the person that is going to tune it and see what they like.
All are good choices. Also comes down to price and what functions you want. Have a good read in the Forced Induction section as these topics have been covered millions of times.
Edited by PM-R33
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
