Hi Guys,
Just wondering what would happen if the RTA had made a discrepancy on your cars year make... EG... 1993 Skyline R32 // 2007 Skyline R32 ???
Anyone have a similiar experience? And what did you do...
Appreciate any feedback
https://www.sau.com.au/forums/topic/342060-rego/
Hi Guys,
i had something similar when i got my car
i got it from VICTORIA and when they transfered the information to the RTA the year was incorect
had to get a blue slip and then went to RTA and the laidy there made some calls and filled up some paperwork for me then waited like a week for the paperwork to be finalised for the date to be changed to the corect one
https://www.sau.com.au/forums/topic/342060-rego/#findComment-5518527
When I had to get my car registered in NSW because I bought it from VIC, the lady who served me at the RTA entered most (if not all) of the information off the Engineering Certificate and didn't blink twice.
Little bit of advise for future keep: If you have to get an engineering certificate with your blue slip, ensure the engineer has made everything and entirely accurate on the certificate he gives you. Even if he makes a mistake, it would be easy to go back and ask him to correct and reprint another copy to take with you to the RTA. The channels you have to go through with the RTA sometimes are a joke, so its always best to get it right the first time.
I noticed the engineer put SED (Sedan) down on my certificate as the car type, where I think it's meant to be Coupe. So that's what ended up on my registration.
That kind of detail didn't bother me so I just went with what I was given. However any other detail like Odo, year, model, etc I can imagine would be rather annoying.
Edited by Owens
https://www.sau.com.au/forums/topic/342060-rego/#findComment-5518781
Most likely entered the year of compliance as the year of manufacture. Happened to my old S13, advantage was that i didnt need to get a pink slip for the 1st 3 years of ownership. Didn't have any issues with rego transfer etc. Best to speak to the RTA
https://www.sau.com.au/forums/topic/342060-rego/#findComment-5518907
Thank You for your feedback guys... Much appreciated
Will it affect ones insurance if their car is registered under a 07 model where it actually is a 93 ? Would you still be OK to claim incase of any accident
https://www.sau.com.au/forums/topic/342060-rego/#findComment-5519985
not sure i would get that rectified ASAP and call your insurer and ask if they will cover as they need to have the corect details in their system otherwise you might end up with the insurer saing sorry you are meant to have a 2007 car not a 1993 car
think of it this way 2007 car will have alot more safety features than a 93 car and will be looked at diferently by insurer both cost wise and safety rating
minimum i would do is make sure the insurance company have the corect details ie 1993 model
https://www.sau.com.au/forums/topic/342060-rego/#findComment-5520207
The thing with imports is - that if the car was complied in 2007, then according to the government it was build in 2007.
Hence the build tags with complicance dates on it, because the car was built in 07 to comply with the Aussie standards.
RAWS workshops are a car manufacturer, if you go by the wording in the legislation.
It is normally ignored, but it might explain why the rego has the 07 manufacture date.
https://www.sau.com.au/forums/topic/342060-rego/#findComment-5521871
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
    • thanks GTSboy. My confusion at the moment is i am trying to locate the ignition, ECU battery power and the ECU negative The closest thing i can find is the for the S15 on Page 8 of the Wiring Specialties web page https://drive.google.com/file/d/0B9F33_M_GgENQnZ6STMxVmVNd1E/view?resourcekey=0-eZ4nNRwRoqa1qvKlWWHm8A I cannot find the same diagram for the R33 RB25DET Series 2 dash plug pin out.... Do you know what the Pins? or know where i can find the same pinout diagram for the RB dash plug? Thanks for the advice on the box... i like a 6 speed so might be on the lookout or the box now.. a topic of discussion for another post...
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
