Selling a full set of Recaro seats out of an Evo VII (JDM).
Includes:
2x Front seats with original rails
and matching rear seats, all in perfect condition
Price $1500
Pick up only in Sydney
Example of what they look like:
can you do the front for 800?
Sell just the front seats no rails just the recaros them selfs
Ok guys I will separate the front from the rear, but will not separate rails.
So front pair with rails for $1200. Not willing to go any lower unless you can find me a buyer for the rears.
  • 1 year later...
  • 1 year later...
