I have recently purchased a rb25 turbo (op6 rear housing) for my rb20. Ive done turbo swaps before and the oil and water feed lines are always a pain in the ass so this time i wanna do it all with braided lines, My question is where can i get a set of braided lines to suit this turbo on my engine?
Any help would be appreciated
https://www.sau.com.au/forums/topic/342289-help-me/
Search Kinugawa on ebay, hes a reputable seller and has good quality items.
If you go to pirtek or enzed you will need to tell them the sizes etc and it will cost alot.
Kinugawa sells kits on ebay, just make sure you buy the right one. If you have any trouble finding one post back and Ill find it for you on ebay tonight after work.
https://www.sau.com.au/forums/topic/342289-help-me/#findComment-5521893
Thanks guys, ill check ebay now. Are the fittings on 25 turbos the same thread size an pitch as 20 turbos?
An r31nismoid i thought braided lines were alot better than the factory steel ones, better flowing an less restrictive? Yes ill only be take this turbo off once but there a head f&*k when it comes time to bolt them back up. And i didnt wanna run the risk of crimping the lines when removing/ installing the turbo.
https://www.sau.com.au/forums/topic/342289-help-me/#findComment-5521967
like nismoid said your better off keeping the factory lines, just replace the brass washers with new ones and away u go. braided lines would be a complete waste of time on a stock turbo. and its actually very easy changing the turbo over..with the right tools
https://www.sau.com.au/forums/topic/342289-help-me/#findComment-5521986
They are not better flowing or less restrictive. Who said that?
A "X" diameter piece of hose will flow the same whether its braided teflon or steel mate.
What you'll run the risk of, with braided, is potential perish/failure over a few years. There are no pro's to going braided for a daily driver
https://www.sau.com.au/forums/topic/342289-help-me/#findComment-5521990
I also believe its better to use the stock lines, best bet is to not unbolt them from the turbo when you remove it. That way it simply bolts back on. Remember there are only 2 to contend with lol, the other 2 are the return and one that connects to a rubber hose.
If you must remove the lines then only thread them in loosely until you mount the turbo, then start up the threads on the block and tighten it all up! That will give you some extra flexibility to get the line back in place. Dont worry too much if you bend the lines a little, just do not crimp them.
https://www.sau.com.au/forums/topic/342289-help-me/#findComment-5523238
    • Is it alright to top up with just another green coolant?
    • thanks GTSboy. My confusion at the moment is i am trying to locate the ignition, ECU battery power and the ECU negative The closest thing i can find is the for the S15 on Page 8 of the Wiring Specialties web page https://drive.google.com/file/d/0B9F33_M_GgENQnZ6STMxVmVNd1E/view?resourcekey=0-eZ4nNRwRoqa1qvKlWWHm8A I cannot find the same diagram for the R33 RB25DET Series 2 dash plug pin out.... Do you know what the Pins? or know where i can find the same pinout diagram for the RB dash plug? Thanks for the advice on the box... i like a 6 speed so might be on the lookout or the box now.. a topic of discussion for another post...
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
    • Staring on a stand is no issue. You just have to wire everything up, give it fuel and cross your fingers that the stand is robust enough. Arranging the inlet plumbing is often the hardest part, without any surrounding structure to hand some of it from. No need for coolant if you only want to run it for <1 minute. As to the gearbox - I think the little Aisin box is a bit stronger than the other small Nissan boxes that went behind SRs, but I wouldn't be too keen to test its limits with the torque of a boosted 25. I don't know if you can retain the box and the tailshaft. The box won't connect to the RB without an adapter of some sort, which is either a plate that will push the engine forward (which is not good for fitting it into the bay's available space) or push the box back, which messes with the box position and tailshaft length - OR - cut and shut work on the bellhousing, which is a long way from "least modification". I'd be buying a new 370Z 6 speed or similar, doing what has to be done to that to make it fit RB (ie, cut and shut bellhousing) and the requisite tailshaft custom/mods.
