For sale or swap:
1998 Nissan Skyline r34
2 door 5 seater coupe
Black
manual transmission
turbocharged engine. (rb25det NEO)
120,XXX km's
traction control
HICAS 4 wheel steering.
driver and passenger airbags
electronic fold side mirrors.
factory nissan Xenons with electric control.
boost, battery and oil guages in cabin.
alot more.
car was just imported may this year.
drives like it is brand new.
(don't hesitate to come and check it out.
test drive welcome to serious buyers)
it is really clean with no scratches or dints anywhere.
dont let the pictures fool you, it just needs a good wash and cut and polish and will turn out really good.
interior is clean, with original carpets.
i removed the spoiler just to see how it looks.
spoiler comes with the car.
car came completely stock from japan besides:
Heavy duty clutch
2x ORIGINAL Recaro sr3 bucket seats valued at 1,200 +
SSR SP1 PROFESSORS. 18inch deep dish.
18x8.5 +30 235 fronts
18x9.5 +18 265 rears
decent tread on both valued at over 3,000
(rims 4k when brand new)
with the right suspension mods, will look really aggressive.
blue under car neon lights with in cabin switch
I can change the price depending on what you want to come with the car,
dont hesitate to send me a pm with your offer/swap.
Asking for: $15,000 (without the rims and standard seats) or $18,000 including the recaro seats and SSR's
Contact: Ken on 0435767585
cheers
167354_2010101143.jpg167354_2010101121.jpg167354_2010101103.jpg167354_2010101125.jpg167354_2010101110.jpg167354_2010101152.jpg
Edited by kenjz
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
