Here I have listed my R34 Skyline coupe, Selling reasons i have no licence ATM so no use in having car. This car is a NON TURBO and would suit well to any p plater. This car is 5 speed manual. Car has just recently run out of rego, though the car can easily been re registered if NSW buyer i will provide inspection papers, The cars features are as listed:
  • Full Japanese import, fully complied with Australian standards to be registered in any state of Australia. imported by previous owner in July 2007, with 79,000kms on the clock. purchased car with 84,000kms..
  • New spitfire performance coil packs added 8000km ago.
  • Factory front strut brace
  • 18 inch versus racing wheels with an RRP of $3000. New rear tyres, R18/35/235 on front and R18/35/265 on rear.
  • Full exhaust system that has cost me $2500 in total including a set of extractors, new hi flow cat and a full 2.5 inch cat back exhaust with 2.5inch chrome dump tip.
  • Clarion head unit with 4 speakers.
  • Factory rear wheel steering.
  • Car comes with super low king springs though not installed.
  • Has just had a new Heavy duty sports clutch installed 500km ago.
  • Gearbox has been fully rebuilt 4000kms ago.
  • Factory fitted floor mats.
  • K&N panel filter.
  • Car is serviced every 5000kms with fully synthetic Nulon oils.
  • Tinted windows.
ALSO!!!!!!!! i must point out there is a scrape on the back bumper from when i backed into my Mrs celica when she first bought it. wasn't used to it being on the front lawn. very minor scrape on the drivers side rear bumper. no cracks to bumper just a bit of a scrape in the paint. in the picture of this the scape is only small. looks larger but car is a bit dusty, please bear that in mind.
Price: $12,000ono
For More Information or to view car call or text Nick on:
Mobile: 0403429340
Home:0269713832
I would prefer to be call or texted rather than PM'd as I am not on here often.
Edited by eat-a-v8
yeah you will probably have good luck on carsales but it costs you $60 to put a advert up on them, its how they make their money, i might have some cash soon once i sell a few cars, but not 12 grands worth. see what happens if its still for sale later on i might be willing to purchase. my offer for the VL's is still there ( Just joking i know you dont want them ).
As long as it sells im not worried about the $60. :) this is the new advert guys, http://www.carsales.com.au/all-cars/privat...id=12C35AD7D43C
Also skywine i reaon keep your VL's and build up a nice one as a cruiser for your P's, they are sexy pieces of machinery. ill post up some photos of my current VL soon. im sure you'll like it :).
Only pic i could find :). ill take some more later as looks a little different now. and has engine in now so front end isnt so high.
Edited by eat-a-v8
mhmm thats a gawjus VL man, but i want something abit newer, and if i was to build a VL, id build a fat 355. not a big fan of the RB30 in them . Im gonna pm you, wanna find out something about this r34
31st of July 2010. So it will need a blueslip for NSW rego. But for a little extra cost I can have one organised. As I mentioned above the only reason i havent re-regoed is I havent had a licence.
Edited by eat-a-v8
ok ill throw you an offer 9500
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
