  • Replies 48
Am i right in reading that its a L2S license, rollcage/harnesses type event or have i read the regulations wrong? I didnt see a price either.
The attached entry form should be completed in full and forwarded to the Event Secretary with the entry fee of $170.00
The Competitor and both crew members shall be required to hold a current CAMS Clubman Rally Licence or L2S or superior
I don't believe you require either rollcage or harnesses, just if they are installed then they will need to meet CAMS Regs.
My reading is that it is a Stage 1 event, which does not require a rollcage or harnesses, but if you have them, then they have to comply with Schedule J. The point that I was less clear on was whether just the driver needs a L2S licence, or whether the navigator does as well - which would seem daft, as the driver must drive 100% of the time. If the "co-driver" is to drive, they must do a separate entry.
I think.
I am sure "Speedaware" would be happy to answer queries.
I would love to do this, but neither the GTR or the Pulsar would be ready for next week or even December. I am not sure I could prepare either car adequately for January/February either. So maybe next year. Definitely keen on trying this kind of event, though.
Cheers. ;)
Edited by MLCrisis
Is Will driving, or are you sharing the drive ?
Yeah it'll be Will, bugger we'll be in the same class, doesn't look like it matters if you run semis or not..
oh well I'll have to try and make up some time on the straights.
as for the course, if you've ever done any of the little motorkana courses down there, apparently its all them joined up, including that little goat track between the strip and the roads over the back :P
I'll let you know after thursday..
as for the course, if you've ever done any of the little motorkana courses down there, apparently its all them joined up, including that little goat track between the strip and the roads over the back :D
Yeah, I thought the course would be something like that. Should be pretty good fun :P
Lets chuck in extra 35-40 kilos in your car :)
Mate I'm not on no diet, and remember its a GTR so no light weight :) but yeah no point carrying more than you have to, I'll be taking the spare out :D but thats about it..
did you get your turbo sorted after Shannons, that hurts, to have to pull out first thing, after shelling out $600 for the day?? :P
night went well, pretty fast course, over 200kms in a couple of spots ( they were the only times I look down ) hard to see some of the corners in the dark, and a bit slippery on street tyres, but a shit load of fun, a few incidents more left on trailers than came on them and a lot came on them,
thought I was doing alright until I found out the sticky tyred, caged up Evos were 10 seconds quicker than my 2mins 35sec,
I'll post up some videos when I have a chance the edit it tonight maybe..
Yes was a good night , top 4 spots were Evo's . Good to see Bruce listened to our advice n dialled up the big launches , 1 nasty GTR :blush:
Franz 1st
Ross
Simon
Will
Awsome event and keen to run in the next 1
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
