When i used to beat the hell out of the Supra i had Ultimates on and i found they did fade on occasion (usually around 3am) i upgraded to the Green stuff and never had a problem again. The fluid was DOT 4 and had been changed very recently so it wasnt that. In my opinion nothing is as important as brakes on the car, this may have something to do with my master cylinder blowing last week when i was on a 3am tourist drive through kings park ;)
Neil @ perth brakes is the guy we usually do a bit of a group buy with as he's my cousin and generally helps us out if we get a big enuff order together.
The ferrodos are good i hear but a bit on the expensive side, the rb74s seem to get a good reveiw from everyone so thats what id go with if i were u.
Thought about a rotor upgrade? Skyzerr and Gradenko did that a while back and they are pretty good for the price around $500 i think from my shot memory but dont quote me.
Try the DBA RB74 pads; they seemed to get some positive response and go for $120 a pair.
Decent pads, when bedded in properly, won't squeal excessively.
I'm on RB74's too. Made by RaceBrakes btw, not DBA. Excellent pad for the money, much nicer than the Ultimates I used previously. The RB74's aren't the most disc-friendly pad around, but they don't fade like Ultimates can, and they take a lot more punishment without dumping resin all over your discs. They did squeal when I first put them on, but that could be put down to heat stressed & worn factory discs - they're quiet as a mouse with DBA slotted rotors on.
G0DF4Th3R, not much dust with these. No where near as much as with Ultimates anyway.
XRW, Ultimates *are* metal and *do* chew discs. Why are they good again? ;)
I personally won't be using anything BUT RB74 Pads from www.racebrakes.com.au (they are abit more than $120/set too). No squeel, excellent stopping power and no fade (im using DBA4000 + Braided lines + sleeved master + master cylinder brace + DOT5.1).
  • 5 months later...
Gents,
time for a brake pad change i think(2-3mm) left, but decided to either go for either RB74's and Ferodo TS2000 but got quoted
for RB74's $145 (front) and $165 (rears)
and for Ferodo TS2500 $160
Where are you guys buying yours? These are from racebrakes direct and perth brakes respectively.
And one last thing.. R32 GTST type M doesn't have the same brake calipers as the R32 GTR's do they?
After last months sprint day at wanneroo,which consisted of 5x 2 lap runs,the Bendix ultimate pads i where using performed patheticly.They overheated,turned to charcoal and glazed/overheated my rotors(DBA slotted).
I had been using the cheapest road version Endless pads(from Xspeed) and could not complain at all about them.
For you mums Camry,go for Bendix.
(yes i have Skyline 4pots on my R30)
Todd
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
    • Does the scanner do all the CUs in the car, or only the ECU?
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
    • Correct. Um. I dunno. I haven't cared enough about the way that the NA cars work to know for sure. But..... The 33/34 turbo manual cars have an electronic speed sensor in the gearbox that outputs a +/- (ie, sawtooth AC) voltage signal. That is connected to the speedo. The speedo then outputs a 0-5v square wave (ie, PWM) signal that the ECU (and any other CU on the bus) sees. The speed sensor is NOT directly connected to the ECU. So here's the problem. Your new ECU expects to see the PWM signal, but must somehow be getting a direct signal from the diff speed sensor. Which would suggest that the wiring of the NA car is not the same as the turbo cars. I think you will need to spend some time with (hopefully the wiring diagram for the car) and a multimeter to see what is connected to what. Then, presuming I am correct**, you would then want to separate the ECU speed signal input from the rest of the car's wiring, and probably either buy a speed signal converter, or build one using an arduino (or similar). That would take in the speed sensor signal and output a scaled (and suitably rearranged) signal for the ECU. ** We shouldn't presume that I am correct here, because there might be something else crazy going on. I don't think you could convert the speedo to be fed from the gearbox sensor, because the pulse rate from that sensor is probably different to the diff sensor and then the speedo would read wrongly. And this also wouldn't fix the ECU's problem either, because the ECU doesn't want to see the gearbox signal direct either (assuming that they are all on the same wiring, for some odd NA related reason, see above caveat!) Does this help? Probably not. Can you make it work? Almost certainly. With the above work. You should buy a handheld oscilloscope from Aliexpress so that you can view these signals directly. Connect up the probes and drive the car. Show photos of the screen when drving at known speeds and connected to different places, and we'll see what we can learn about it.
