ITS STILL THERE ARRRG!!!!!!!
gunna run a colder spark plug see if that helps im trying the bcpr6es ngk ones will post up results
a stock tune wont ping, get it to a tuner! you have a sensor that has shit itself, something wrong with the fueling eg clogged injector or dead pump or someone has gone and wound the base timing up, plugs wont do anything.
everyday you drive it the more damage you do to your pistons and bearings!
Edited by Rolls
i read around today and there has been a couple of ppl with the same issuse caused by the wrong plugs im not saying your wrong or anything i am willing to try anything but its my daily...
this is something i found
A spark plug does not make your engine run hotter or colder. The terms hot or cold refer to the temperature of the tip of the spark plug itself. The plug must keep a temperature of, between 752 and 1652 degrees Fahrenheit. If it gets too hot it can fire off the air/fuel mixture at the wrong time. This can cause detonation and/or pinging which will put a hole in your piston... not good. If it gets too cold it will not burn off the carbon and fuel deposits on it's tip and the plug will foul out (stop working) not good either.
and this is a link to someone else that had the same issuse caused buy plugs..
http://www.skylinesaustralia.com/forums/St...ed#entry4989491
HATING LIFE RIGHT NOW
If you have a plug from the opposite end of the scale maybe or the tune is right on the edge of detonation but it is unlikely with a stock tune as they are so bloody rich and have all the timing pulled out of them.
Sounds more like the typical misfire than pinging to me from what I read in that thread but I could be wrong.
Edited by Rolls
i have been busy cleaned the afm and intake pipe
changed the plugs
checked the pump Which i think may be on its way out which is one thing that could be the issue leaning out becuse the pump cant supply fuel?? it is starting to sound slugish when its primeing
also there is a bit crap in the filter of the pump so wont be suprised if its f*ked
checked the knock sensors..this was intersting one of the knock sensor loom plugs the one beside cylinder 4 an 5 is broken the plug clips in but is dodgy as and the actuall sender was only fingertight will this cause it to ping ive read that in improperlly torqued knock sensor can cause pinging
took out injectors today and there shagged all of the hard plastic casings round the squirters are broken off or cracked they eould be leaking like a siv lol gettin new one tonight will be in tommoro hopefully all systems go
all roght my cheapness bit me in the ass i did not reseal the injectors and the pingin is still there and the ecu is shooting the same codes if i am even reading them right the first code thats throne is 23 which is 2 long flashes followed by 3 fast flashes which i read as 23 which is idle switch yeah?.
the next lot of flashes confuses me cause i get 4 fast flashes followed by another 5 flashes which i read as 45 and is injector leak but is supposed to be flashing so fast on the second read out?
and i discoverd my flange gasket is gone on my turbo and is leaking could this contribute in any way
ok im getting close to driving the car down to the dump becaus same issues stil..
in the last two weeks i have resealed the injectors which did not help. but i did not use genuine seals which im not keen putting genuine one in on week end
but have also put a walbro pump in to have the same issues now i think it maybe something to do with the tank itself or one of the feed or return lines because i bought a genuine fuel tank inspection flange seal and i still had fuel leaking out of there not as much as last time but still enought to be fumy as in the cabin..
so i bought some aviation form a seal i have used it before to seal tanks with no issuse but on when i put it on this one all around the fange and just around the ends of the feed and return at the tank my pingin has got a whole lot whorse so it may have something to do with it but what ??
Cracked feed or return maybe sucked some form a seal has been sucked up any brainstorming will help thanks
    • The car/ECU will have all the sensor that it needs and expect to have. I think i do not have to explain to you how the Link is way better specialy if you have swapped engine   I just do not want to deal with any "problems" cuz i have only Nistune which i learned is not that great and in my case cant even deal with that speed problem (Link can) And of course it will be way more easier to tune and diagnose and safe. And for the ECU/speed problem...i dont know.
    • Per Mark Roberts of Sonictune: Mark Robert Author At this time, no. No ETA either 2016-17 models. You will be able to purchase and install a 2018.5+ TCU though   TCU purchasing and pricing info! As we near the release of TCU tuning, I am going to answer some questions I get asked often.   What do I need for TCU tuning? At this time, you will need a 2018.5+ TCU to be able to tune. If you have a 2016-to early 2018, you will need to replace your TCU with the newer version. One good way to know if your TCU is good is if you have auto upshift in manual mode in 1st gear around 6500 rpms. If your manual 1st gear goes to 7k rpm and will hit the rev limiter unless you shift, you have the older TCU.   Why do I need to buy another ecu license/phone flash if I already have it on my ECU tune? The TCU is its own computer module. It is completely separate from the ECU. Because of this, you will be required to purchase a TCU license and, if your tuner has it, the phone flash license required to tune it via phone/bluetooth.   Do I need TCU tuning? TCU tuning is NOT required. However, the faster your setup, the more it will assist in track and dragy time consistency.   If I’m ECU tuned by (tuner A) can I get my TCU tuned by (Tuner ? Yes, since it’s a different module and a completely separate flash, you can have two different tuners. However, it is highly recommend that you have both tuned by the same tuner. For me, my TCU tuning will directly complement my ECU tuning style and features and running my ECU and another TCU or vice versa MIGHT cause some issues. At this time and for the foreseeable future, I will only be tuning my current ECU tuned customers TCUs.     I have a SYVECS AWD controller. Do I still need it? Yes! The AWD controllers main job is to control your AWD system. However, with TCU tuning, you will no longer need the auto-shift function as that will be done through the TCU. The AWD controller will still be very beneficial for racers looking to maximize traction on the launch.     Shift schedule changes: holding gears longer at lower pedal input as well as max shift rpm changes. Please note, the new ECU race rom coming out will address 90% of the shitty drivability issues these cars have through custom maps from myself and Racebox—as well as others I am sure.   Increase shift speeds: as seen in the videos I’ve been posting, the TCU shifts much faster once tuned.   Increased shift pressures: as also seen in the videos, much firmer full throttle shifts.
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
    • Very good news...I contacted Racebox about it last night. My car is a 2016 so remains to be seen if it is compatible, requires a TCU swap, or is impossible.
