zeds are so heavy complex and the short wheelbase is ansty in the wet.. hicas always fail, so do electrics and most have been stacked sometime... engine is a bitch to work on also.. they are as cheap as chips in Japan now... my 180 did a 12.3 at Heathcote with me backing off halfway shows how heavy the zeds are.
  • Replies 71
LOL:lol: Backed off halfway and still ran 12.3!!!!! Dude you must have a 10 second 180SX! Now thats a timeslip I bet we don't see:lol:
You've had a lot of experience with Zed's hey? or read a lot of magazines more likely:D
A two seater Zed has a 2450mm wheelbase and a 2+2 is 2570mm,
I wouldn't think a 180SX or Skyline is much longer than that, but I'm no expert, and I don't pretend to be either:)
My Zed must be a little unusual, not having any electrical failures or HICAS problems
yes had one for a while I know it was bad but almost the biggest pile of junk I have owned.. 1.7 60 foot, at 100mph I'll post the timeslip... it was running slicks and has 300kw at the rears... Front left wheel bearing was dodgy and car kept pulling to the left under hard acceleration....
Doesn't really show how heavy Z's are, just shows how much power you make.
What we're impressed with here isn't out right ET, but how little it takes to reach that. I've done a little searching and seems it isn't uncommon for a stock turboed, stock injectored, stock intercooled Z's to run mid 12s (or less). I guess being able to run over 1.1bar without the exhaust wheel flying off helps :D I think we all know what the limits of stock sr20 bolt ons are in comparison...
Originally posted by JiMiH
Is it true that 300zx's are very hard to work on and if anything goes wrong then big bux to fix?
Coz otherwise I reckon they are sweet looking cars :uh-huh:
It's all relative.....the Zed is fairly complex, and space is tight, but its really not that bad, I've got three in my garage at the moment, one with engine and box out and in pieces.
Hasn't been one instance yet where I have had trouble working on them.
For instance, I can get an auto box out in around an hour no problems :(
Parts are plentiful and quite cheap for 2nd hand bits, if you have to pay a mechanic, then obviously labour is expensive. Virtually all mechanics are completely overwhelmed when they pop the bonnet, and convince themselves it's too hard before they start.
Aside from the engine, all the other mechanicals are pretty much the same as all other turbo Nissans. And as you guy's know, very tough:)
The main problem is when people foolishly buy one in poor condition, have a few things go wrong, then spout off to all and sundry that the Zed is crap:( If they bothered to look at the vehicle prior to handing over the loot they wouldn't have a problem, but that applies to any car. If you bought a blue car and it crapped out, would that mean all blue cars are crap?:)
My personal opinion is that the Zed is the best value for money of any equivalent car. I like Skylines too, so don't linch me:)
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
