  • Replies 181
front pipes $80
sunvisors SOLD
interior mirror $20: SOLD
interior lights $30
dash loom $100
interior carpet $70
boot carpet $60: SOLD
heaterbox/ all under dash make an offer: SOLD
rb26 cam/timing belt cover $60
speedo 140,xxxk's $40
rear end, brakes all there $800
intercooler mesh $20
trust pod filters x 2, $70
monster tacho with shift light $50: SOLD
steering wheel $40
GTR fuel pump exc. working order $70
glovebox $30: SOLD
HICAS computer $50 plus have other little computers from throughout the car
have ALL windows except drivers side
rear wiper + motor $40
boot release with fuel flap popper $20
side mirrors $40 each
bonnet squirters $20 SOLD
bonnet heatshield $60
A,B,C pillars
clutch master $40: SOLD
brake booster $40
accelorator with cable $50 brake and clutch pedals $30 each
steering rack $150: SOLD
metal plate that goes inbetween rear seat and boot $60: SOLD
windscreen wipers $30 pair: SOLD
window wiper motor $30
overflow and washer bottles
kickpanels $20 each
cooler piping one side $20
wheelnuts full set $10
rear passenger seatbelt $20
rearseat in mint condition $150
boot rubber seal perfect cond. $40
drivers door window switch $50
rb20 crossover piping $30
turbo timer exc. working order $30: SOLD
handbrake $30
random 8 inch subwoofer never been used $20
Drivers side reverse light: SOLD
door sills that say skyline $20 each
wheel well cover from in the boot $30
gearbox mount $50
interior door handles $5 each
car loom
1 N1 vent need respray. offers
Front cradle is there still, hubs etc.
final drive shaft
centre console no lid $30
rear bar, haggard suit drift pig
rear boot trim
GT badges $10 each
fuel flap $10
space saver wheel
C Spanners x 2
tailshaft
interior door wiring
wiring from throughout the car just ask
bonnet hinges may be a little bent $20 for both sides
passenger door rubber no rips or leaks $30
battery clamp $10
engine mount $10
:thanks:
front pipes $80
sunvisors SOLD
interior lights $30
dash loom $100
interior carpet $70
steering wheel $40
glovebox $30: SOLD
A,B,C pillars
brake booster $40
kickpanels $20 each
handbrake $30
gearbox mount $50
car loom
final drive shaft
rear boot trim
GT badges $10 each
fuel flap $10
space saver wheel
C Spanners x 2
tailshaft
battery clamp $10
engine mount $10
It's the weekend bump :)
Okie Dokie
Prices dropped AGAIN :)
Photo's aswell, yes my garage is full of GTR shite, please help me clear it by grabbing a bargain!
front pipes $60
sunvisors SOLD
interior lights $20
dash loom $60
interior carpet $40
rb26 cam/timing belt cover $40
speedo 140,xxxk's $30
rear end, brakes etc. everything there $700 Buyer organises postage
trust pod filters x 2, $50
steering wheel (310mm) $30
GTR fuel pump exc. working order $50
glovebox $30: SOLD
HICAS computer $40 plus have other little computers from throughout the car
rear wiper + motor $30
side mirrors $30 each
bonnet heatshield $40
A,B,C pillars
brake booster $30
accelorator with cable $30 brake and clutch pedals $20 each
window wiper motor $30: SOLD
overflow and washer bottles $15 each
kickpanels $20 each
rearseat in mint condition $80
boot rubber seal perfect cond. $20
drivers door window/mirror control $40
rb20 crossover piping $20
handbrake $20
random 8 inch subwoofer never been used $10
timber wheel well cover $30
gearbox mount $50
car loom
input shaft $50
rear bar, haggard suit drift pig. $10
rear boot trim
GT badges $10 each
fuel flap $10
space saver wheel $20
C Spanners x 2 $30
tailshaft $70
battery clamp $10
engine mount $10
upper control arms $50
left and right cv with knuckles $80 a side
rear pod/ side skirt things make an offer
I'm on here everyday so feel free to PM or post in here
:cheers:
rear bar, haggard suit drift pig. $10 drift car it will suit. haha
all SOLD
Brodie,
This is les.
I am after an R32 GTR Bonnet Latch - the part bolted onto the front and holds down the bonnet.
Have got?
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
