  • Replies 181
Photo's on previous page
front pipes $60
sunvisors SOLD
interior mirror $20: SOLD
interior lights $20
dash loom $60
interior carpet $40
boot carpet $60: SOLD
heaterbox/ all under dash make an offer: SOLD
rb26 cam/timing belt cover SOLD
speedo 140,xxxk's $30
rear end, brakes etc. everything there $700 Buyer organises postage
intercooler mesh SOLD
trust pod filters x 2, $50
monster tacho with shift light $50: SOLD
steering wheel (310mm) $30
GTR fuel pump exc. working order SOLD
glovebox $30: SOLD
HICAS computer $40 plus have other little computers from throughout the car
have ALL windows except drivers side
rear wiper + motor $30
boot release with fuel flap popper SOLD
side mirrors $30 each
bonnet squirters $20 SOLD
bonnet heatshield $40
A,B,C pillars
clutch master $40: SOLD
brake booster SOLD
clutch slave cylinder $30
accelorator with cable $30 brake and clutch pedals $20 each
steering rack $150: SOLD
metal plate that goes inbetween rear seat and boot $60: SOLD
windscreen wipers $30 pair: SOLD
window wiper motor $30: SOLD
overflow and washer bottles $15 each
kickpanels $20 each
cooler piping one side $20
wheelnuts full set SOLD
rear passenger seatbelt $20
rearseat in mint condition SOLD
boot rubber seal perfect cond. $20
drivers door window/mirror control $40
rb20 crossover piping $20
turbo timer exc. working order $30: SOLD
handbrake $20
random 8 inch subwoofer never been used $10
Drivers side reverse light: SOLD
door sills that say skyline $20 each
timber wheel well cover $30
gearbox mount $50
interior door handles $5 each
car loom
1 N1 vent need respray. SOLD
Front cradle is there still, hubs etc.
input shaft $50
centre console no lid $30
rear bar, haggard suit drift pig. SOLD
rear boot trim
GT badges $10 each
fuel flap $10
space saver wheel $20
C Spanners x 2 $30
tailshaft $70
interior door wiring
wiring from throughout the car just ask
bonnet hinges may be a little bent $20 for both sides
passenger door rubber no rips or leaks $30
battery clamp $10
engine mount $10
upper control arms $50
left and right cv with knuckles $80 a side
rear pod/ side skirt SOLD
Front Diff???? ta
PM coming ur way
Speedo cluster and both GT badges SOLD :thumbsup:
Also whoever was asking about top radiator mounts (can't remember who) i do have them. found them this morning :cheers:
front pipes $60
sunvisors SOLD
interior lights $20
dash loom $60
interior carpet $40
speedo 140,xxxk's $30 SOLD
rear end, brakes etc. everything there $700 Buyer organises postage SOLD
glovebox $30: SOLD
A,B,C pillars
brake booster SOLD
overflow and washer bottles $15 each overflow SOLD washer available still
kickpanels $20 each
handbrake $20
timber wheel well cover $30 SOLD
gearbox mount $50
car loom
input shaft $50 SOLD
rear boot trim SOLD
GT badges $10 each SOLD
fuel flap $10
space saver wheel $20 SOLD
C Spanners x 2 $30
tailshaft $70
battery clamp $10
engine mount $10
left and right cv with knuckles $80 a side SOLD
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
