  • Replies 181
front pipes $60
sunvisors SOLD
interior mirror $20 SOLD
interior lights $20
dash loom $60
interior carpet $40
boot carpet $60 SOLD
heaterbox/ all under dash make an offer SOLD
rb26 cam/timing belt cover SOLD
speedo 140,xxxk's $30 SOLD
rear end, brakes etc. everything there $700 Buyer organises postage SOLD
intercooler mesh SOLD
trust pod filters x 2, $50
monster tacho with shift light $50 SOLD
steering wheel (310mm) $30
GTR fuel pump exc. working order SOLD
glovebox $30 SOLD
HICAS computer $40 plus have other little computers from throughout the car
have ALL windows except drivers side
rear wiper + motor $30
boot release with fuel flap popper SOLD
side mirrors $30 each
bonnet squirters $20 SOLD
bonnet heatshield $40
A,B,C pillars
clutch master $40 SOLD
brake booster SOLD
clutch slave cylinder $30
accelorator with cable $30 brake and clutch pedals $20 each
steering rack $150 SOLD
metal plate that goes inbetween rear seat and boot $60: SOLD
windscreen wipers $30 pair SOLD
window wiper motor $30 SOLD
overflow and washer bottles $15 each overflow SOLD washer available still
kickpanels $20 each
cooler piping one side $20
wheelnuts full set SOLD
rear passenger seatbelt $20
rearseat in mint condition SOLD
boot rubber seal perfect cond. $20
drivers door window/mirror control $40
rb20 crossover piping $20
turbo timer exc. working order $30 SOLD
handbrake $20
random 8 inch subwoofer never been used $10
Drivers side reverse light SOLD
door sills that say skyline $20 each
timber wheel well cover $30 SOLD
gearbox mount $50
interior door handles $5 each
car loom
1 N1 vent need respray SOLD
Front cradle is there still, hubs etc.
input shaft $50 SOLD
centre console no lid $30
rear bar, haggard suit drift pig SOLD
rear boot trim SOLD
GT badges $10 each SOLD
fuel flap $10
space saver wheel $20 SOLD
C Spanners x 2 $30
tailshaft $70
interior door wiring
wiring from throughout the car just ask
bonnet hinges may be a little bent $20 for both sides
passenger door rubber no rips or leaks $30
battery clamp $10
engine mount $10
upper control arms $50
left and right cv with knuckles $80 a side SOLD
rear pod/ side skirt SOLD
BUMP
Front pipes $60
Interior lights $20
Dash loom $60
interior carpet $40
HICAS computer $40 plus have other computers from throughout the car $30 each
A,B,C pillars
kickpanels $20 each
handbrake $20
gearbox mount $50
entire car loom $150
fuel flap $10
C Spanners x 2 $30
interior door wiring $5
battery clamp $10
engine mount $10
radiator cap $10
HICAS pump $50
map light interior $10
HICAS bottle from boot $10
This is all i have left, take it away so i can have my garage back! Will do cheaper prices if u buy multiple things ;) cheers
Do you have the tps sensor on the plennum for sale!?
Also what side Is the engine mount you have for sale!?
Pm message me
Cheers josh
Edited by joshua shirvington
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
    • Yeah that looks like great caster, but I'd suggest trying less front camber some time and seeing if it helps with braking without reducing mid corner speed too much
    • I ended up setting the rear 5mm higher than normal to give some clearance.  My plan is to run the least camber I can in the rear which I think with the extra width is going to need to be -1.75 to -2.00° just to get clearance.  Guards have been rolled and pulled as much as they can/I would be wanting to.  front has the Acostal knuckle with the KPI change and the drop etc. So should be okay with the existing settings I have run with AR1s etc Front: Toe total -2mm(1mm out each side) Caster +7.5° Camber -3.8° Ackerman +15°
