  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
i don't get defects .. just speeding.. last 10 years.. every year.. a smart man would drive slower..
(i am not that smart man)
ps: ska, thanx for the help today .. when i finally found BDA (i was right outside it 2nd phone call).. they were closed :thumbsup: gone on holidays till next week..
ska, thanx for the help today .. when i finally found BDA (i was right outside it 2nd phone call).. they were closed :D gone on holidays till next week..
Bummer eh, you didnt ring ahead..........?
But you now know what i mean, it's hard, but easy to find :thumbsup:
HA HA I only had to make 1 phone call ;)
I was out in one of my friends car one night and there was a bank up on the freeway of traffic so I said to her, wheres your handheld UHF? She's like "why", I said "so I can find out what the hold up is!" She goes "are you just hoping someone is on channel 16?" I said "No ang, watch and learn" so I get the radio, go to channel 40 and go "can I get a road report on the southeast freeway heading south around Juliette Street?" A truckie comes back and tells us they are doing roadworks and we need to be in the left lane. I say thanks and stuff. And she goes "OMG how did you did that" I'm like "oh ang, dear my, are you serious?!" And she was, she thought somehow the radio was a two way (kinda is I guess) and only people that she knew could hear her.. I'm like WTF? Having grown up around CB's being AM, USB, LSB and UHF, it was kinda normal for me to do that :S
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
