  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
dork!
OH OH and you want some of this beatdown you wetern australian dirty inbred?!?!
I have had a shi7 of a day and Charly is just being a passive little biatch like he normally is, musta taken his drugs today! :flamed:
get AIDS and DIE MOFO!
