if you can get him down to 500 for the trust zaust id get it, the muffler is gonna come up at an angle if im looking at the way the hangers are mounted, but also notice that it has a small "hotdog" style resonator, which will quieten it a little and make it less noisy as opposed to my dirty great big rice cannon which deafens small children and the us military accused me of stealing the gun barrel off one of their tanks
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
looks ok.. don't forget postage costs will be steep on an exhaust.
Which is why I doubt it he'll sell it to me for ~$500 INC the postage, but we'll see how low he is willing to go and if he can wait a few months and i might be able to scrape it, maybe in May :)
i would also like to say
http://www.skylinesaustralia.com/forums/sh...ead.php?t=35694 those boots that this guy makes are freakin awesome, i have em in my car and im tempted to buy a spair set just incase the ones i have ever wear out
Yeah I saw them, awesome price, but atm need all the cash I can to scrape through the cat back, but they are on the list, certainly cant buy crappy vinals for that price, and they are leather!
I recently installed a set in mine. They look great and workmanship is top notch
Yep one of my first mods too... Only needed the handbrake boot as I'm the only QLD'er with an auto.. :)
