  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
I've even been just burning stuff quickly on CD-RW before i shoot out, then deleting it when i get back home or get bored of the compilation and putting something else on. Only way to go these days..
hmm.. time to sand back my front bar repair.. excitement plus.. oh well, gotta be done..
/me waits for the slap down from strutto.. :D
you disappoint me strutto...still waiting for the smackdown
maybe i'll get it in person tonight :)
ur not my hero anymore strutto :)
*waits for smackdown*
You dare humiliate your hero in his absence???
I'll see you lot tonight!!!:cuss:
about the boots, i got them and installed them, wasnt hard to sew up either, but then again I know how too ;) he could ahve made some of the edges longer as they might wear in some spots. best buy for that money.
ska, why dont you put niko beside the road you guys are taking then photo copy? or just highlight with grey in paint shop ;)
pred, a cd-rw isnt what you need, you need more money for cd's, with 300 trakcs, (of 12 for me) on a mp3 cd you'll run outta time for burning and erasing the cd's :) thats unless you have 4 rw's like i have but no mp3 player :/
Sorry guys i wont be with you tonight, i have to save cash, and show my brother brisbane, and he doesnt like cars after a certain rollover(dads new hilux). so I cant take him, he didnt even like the drive outta the airport :/ straight and 60-100 in 1 second :D
have a good and safe one.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
