  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Hey strutto how do the azenies feel? smoked em up yet heh
I got my wheel alignment and shit done today and its all fixed.....except my right wheel was slightly pushed back when i hit the gutter theres no adjustment to make it perfect again, but he said its not noticeable and when i drove home it felt good as before so i cant complain.
Im set on getting those yokahama V102's damn they are a nice tyre. $350 each though, but they will fu:)
I've driven maybe half a k on them... But there was 1 corner... They grip heaps more than my Dunlops ever did but still let go eventually... I'll be more able to tell what they are like after a few more k's...
Yep the v102's should be nice...
Nope... Humbucker please!
I'm LH... Like all the greats,  Jimi, Kurt, Cliff... :(
nooooooooooooooooooooooooo. Oh well I guess I can forgive you since you do drive a skyline. (and you are a moderator so It's not like I have a choice) I guess I like the single coil neck pickup tone with a bit of reverb clean better than the Humbucker.
I reckon you're a closet Yngwie Malmsteen fan. :kick:
