  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
sigh... now i really wanna a GTR for myself. JL was over at my place last night to show off his new toy to me, Tze and James. It was SWEET!! Immaculate condition and it looks like it just got outa the showroom.
Think i might wanna sell my car soon to finance a GTR for myself :P
Ben, you keen?
GTR is the go... as long as you can afford the insurance, extra costs, and depreciation involved :P
hey what are those things that look a bit like mosquitos but are like huge (about 10 times the size) ?? there is one in the house :-s
naah... i'm sure he will be cool with it... after all... he had a go at almost everyone here in this forum... including a mod!
also, he did said that this is the internet and everything goes.... and that comment goes as a joke :P
wat cha doing at home on a saturday nite, Pred?? how's the 31?
doing not much..
r31 is still under the house as the council threatened to find me $350 or something stupid for having it sit on the streets unregistered :P so i can only look at it :P
..but i did drive it around the block a couple of times :)
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
